It is currently Tue Jun 16, 2026 10:06 pm
Post new topic  Reply to topic  [ 20 posts ]  Go to page Previous 1 2
PostPosted: Tue May 12, 2009 11:50 pm
I really hope it's something with that ground cable. Could those few cables I removed in relation to the ac really take out the rest of the electrical system?
Nothing smelled burnt and all the fuses under the dash is okey
How should the car be grounded from the begining? Is there one or two big ground cables? Mine went from the battery to that bracket holding the compressor. So it was grounded through that whole contruction wich was attached both to the enginge and the chassi.
My brother told me his car had two grouning cables, on from the battery to the engine and one from the gearbox to the chassi.
1970 Plymouth Duster
PostPosted: Wed May 13, 2009 5:42 am
Trebor
Look close at the Ground strap, I have had these go "bad" when they were disturbed(moved around). My multimeter said it was good and I had radio lights etc but when I tried to start the car just a weak click. Also look real close at where you bolted that ground on. Make sure you have clean metal for the ground to work good.
Just my 02.
Frank
73 Duster - Race Car
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
PostPosted: Wed May 13, 2009 7:44 am
check battery for charge...charge if needed....check all connections clean and tight...should be ground from battery to engine and body and frame...dont forget one from engine to body...keep in mind that body and engine/trans are rubber mounted to frame...also check /clean firewall connector
keep on roddin'
PostPosted: Wed May 13, 2009 12:31 pm
Now it's working thanks to your help!!
I put a ground from the battery negative to one of the p/s bolts and also a ground from the cylinder head to the firewall :D
Thanks for all the advice!!
PostPosted: Wed May 13, 2009 12:52 pm
