It is currently Sat Nov 14, 2026 1:17 pm
 Post subject: Is this Head usable?
PostPosted: Sat Aug 08, 2009 5:43 pm
Take a look at this - One broken Valve guide - Can this Piece be salvaged or not?
PostPosted: Sat Aug 08, 2009 6:03 pm
This is necessary fix as this sleeve forms a part for valve stem seal cap.
Get it pressed out and put new guide in. Check all other guides for wear as well.
Then valve redone and ground in. Um is the engine block in rebuilding as well? This does not make sense to do it if the engine is old.
Cheers, Wizard
PostPosted: Sat Aug 08, 2009 8:49 pm
looks like a good candidate for a cross section chop! :wink:
PostPosted: Sat Aug 08, 2009 9:59 pm
Any thick wall guide can fix that up. You'll need to have at least that one seat redone after the new guide is in.
PostPosted: Sun Aug 09, 2009 7:41 am
If you dont have anything invested in that head and you have another use it. It can be repaired by a machine shop but dont have any clue what it would cost.
Good luck. Are you back to work yet? PM me your address so I can send that Clarinet.
Frank
73 Duster - Race Car
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
Users browsing this forum: Google [Bot] and 11 guests
