It is currently Tue Oct 13, 2026 5:25 am
PostPosted: Fri Aug 28, 2009 8:24 pm
904 LA tranny id 2538473 later model
the starter is spinning but the pinion is not engaging the flywheel
Anyone have any possible reasons as to why this could be?
thanks so much. God Bless
Keni
isaiah6:8
www.kenithomas.com
PostPosted: Fri Aug 28, 2009 8:32 pm
my guess the starter is junk cheaper and easier to go buy a new one than to try and rebuild
Nothing beats a slant six
1987 D150
PostPosted: Fri Aug 28, 2009 8:41 pm
Possibly worn starter gear and/or worn ring gear.
If you are stuck try this: WITH THE IGNITION OFF AND KEY OUT, spin the fan by hand a little bit then try to start the engine.
PostPosted: Fri Aug 28, 2009 9:17 pm
Sounds like the starter is getting a bit worn out,time to rebuild it or replace with a good rebuild. Good luck Keni :wink:
PostPosted: Fri Aug 28, 2009 10:22 pm
Glass 1/2 empty...
The #3 main (crank thurst bearing) is worn, allowing the crank to move reward enough to prevent starter engagement. :cry:
Test by pulling forward on the crank, if it moves forward more then .014, that may-be the issue.
PostPosted: Sat Aug 29, 2009 2:01 pm
Smack the starter with a hammer. It might just be stuck a little.
PostPosted: Sat Aug 29, 2009 2:56 pm
BFH
PostPosted: Sat Aug 29, 2009 9:00 pm
Site Admin
Harley Mechanics. I knew it. :lol:
PostPosted: Sun Aug 30, 2009 6:35 am
Ceej Posted: Sat Aug 29, 2009 11:00 pm Post subject:
as last resort all else was already said.....actually learned
use of BFH working on caterpillars, just transfered to all wrenchingLMAO
PostPosted: Sun Aug 30, 2009 9:06 am
It's not fair that Harley guys get the credit(or blame) for BFH when everyone knows or should that the term was coined in Model T days ie;Big Ford Hammer.
Users browsing this forum: No registered users and 40 guests
