It is currently Wed Feb 26, 2025 12:45 pm
PostPosted: Sat Sep 12, 2009 6:47 am
I have a chance at getting a free SL6 from an A100. My buddy, who owns it, sez it's a 225... how can I tell. I don't know the year.
Check it out... www.symcoshakedown.com
PostPosted: Sat Sep 12, 2009 6:40 pm
Look at the top of the block right underneath the #1 plug. There is a pad that sticks out from under the head that will have the cubic inch stamped in it.
If it's the original motor it should be a 225. Not sure a 170 was ever offered in an A-100.
A-100 motor should have the really neat driver's side alternator brackets too. :D
PostPosted: Sat Sep 12, 2009 7:06 pm
I'll check it out.... thanks.
PostPosted: Sun Sep 13, 2009 6:34 am
Car Model: 1967 Dodge Dart GT
i forget how i determined it, but pretty sure our 64 a100 had a 170, the holes were different for the drivers side alt bracket on it than what our 73 block had, so we had to go "custom" on it...
i think it was noticeably different for some reason though.
PostPosted: Sun Sep 13, 2009 8:02 am
It would be nice if that motor had the factory trans adapter.
It would be even nicer if you passed it on to me!
:D
-James
PostPosted: Mon Sep 14, 2009 7:56 am
Yep! The 170 & 225 were the only available engines until 1964, when the 273 V-8 was added.
Check the 5th digit of the VIN. If it's a B, then the factory installed a 225 in the truck, A for a 170.
You can't fix stupid. - Ron White
PostPosted: Mon Sep 14, 2009 3:23 pm
An A-100 with a 170 in it had to be a gutless pig. :shock:
PostPosted: Tue Sep 15, 2009 6:50 pm
I haven't had a chance to go take a look yet... I'll let you guys know.
PostPosted: Tue Sep 15, 2009 6:57 pm
Easiest way to tell a 170 from a 225 is to look at the bypass hose between the top of the water pump and the bottom of the head. If it is only about an inch long it's a 170. On a 225 it is about 3" long. :shock:
PostPosted: Wed Sep 16, 2009 3:43 pm
Just click on the "engines" page. http://missiondetail.com/a100vans.index.htm
PostPosted: Fri Sep 18, 2009 8:54 am
Great info here... thanks.
Users browsing this forum: Google [Bot], Semrush [Bot] and 16 guests
