It is currently Sun May 10, 2026 2:46 pm
Post new topic  Reply to topic  [ 33 posts ]  Go to page Previous 1 2 3
PostPosted: Wed Nov 04, 2009 8:50 pm
The HEI does have some solid advantages over the Mopar box, but I'm super-suspicious of MSD coils any more, since they're now outsourced to China. :roll:
I'd probably use a spool-type stock HEI coil.
 Post subject: All Hail Hei!
PostPosted: Tue Nov 10, 2009 12:36 pm
Car Model: 71 Dodge D100 64 Plymouth Valiant Wagon
Installed an HEI ignition module with relays over the weekend. Makes a TREEEEEmendous difference. Still using the MSD blaster coil. When I get some more time and money will go with a GM-type.
Running much much better. And thanks to Dan's excellent directions, it was a very simple swap.
Thanks everybody!!
Joe
Joe Hoppe
71 D100 225 Super Six 727 AT on 2008 Crown Vic CopCar frame
64 Valiant Wagon 225 904 AT 3:23 8.75"
PostPosted: Thu Dec 31, 2009 12:43 pm
madmax, he's not running platinum plugs. He is, however, running Autolite plugs, which are now rather poorly made in China.
A switch to NGK ZFR5N plugs, without the metal ring washers, might be a wise idea to eliminate poorly-made plugs as a cause.
I don't have much knowledge of propane engine operation but I have a hard time imagining why an extra-narrow plug gap like 0.030" would be anything but a hindrance.
What kind of Mopar electronic ignition are we talking about? Orange box...?
I second using NGK's. When I ran them in a waverunner I loved them compared to Champion's or others.
Brian Doak CMfrT
Users browsing this forum: cpreal and 1 guest
