It is currently Mon Oct 12, 2026 7:38 pm
PostPosted: Fri Nov 20, 2009 1:15 pm
i have figured where i'm going with my duster SLEEPER! its gonna be realy quiet with turbo mufflers and eletric cut outs when i need them. but i need help with choosing and air cleaner i want something big to let it breath so heres what i got
the air cleaner off a 454 i like it because it can do this
but is there any other options for an air cleaner where it would look stock and perform as well. this was free off my dads truck but i could by something else since i have room in my budget
1973 plymouth duster 225 slant six .30 over, erson 270 cam, 9.5 to 1 compression, big valves, headers, and a holley 4 bbl
http://cardomain.com/ride/3135091
hey that thing got a hemi? naw its just a slant six
PostPosted: Fri Nov 20, 2009 2:44 pm
I seriously doubt you will get your hood to close with the air cleaner lid flipped. It might close with the lid in the normal position.
What's wrong with a stock mopar air cleaner? Find one off of a smallblock. It will clear your hood and, if you get the right one, you can have functioning cold and heated air intake systems.
PostPosted: Fri Nov 20, 2009 2:54 pm
I used the base from a 10'' aftermarket air cleaner with the top from a 1 bbl. air cleaner on my Holley 390.
PostPosted: Fri Nov 20, 2009 7:10 pm
If your hood will close, you could use the one you've got.
However, I'm with Reed on this one. Chcek Ebay, junkyards, swap meets and use a Mopar air cleaner. Or, you could use some type of combo like slanted87 did. If you want that sleeper effect.
'78 Volare 225
'67 Charger 318
PostPosted: Fri Nov 20, 2009 8:53 pm
Turning the lid upside down gives more noise, if you like that, but leaving it rightside up gives the engine what it really wants: temperature-controlled air (hot when the engine's cold, cold when the engine's hot).
I just came across this interesting air cleaner from our friends at GPRS Mopars down under…
PostPosted: Sat Nov 21, 2009 4:53 am
i like the twin snorkel air cleaner how much would that be in american $dollars$.
yea i found out after further fitment tests that its going to have to be modified to fit around the vaccume secondaries. so it ain't going to work cause i don't feel like cutting and rewelding it
what kind of air cleaner did the hyper packs use from the factory?
what should my minimum size for an air cleaner (or element), cause i know the bigger the better but i don't want it to small
i can drill some holes in the bottem if i get a single snorkel and that will work for some more air right?
PostPosted: Sat Nov 21, 2009 6:36 am
AussieSpeed.com has some awesome air cleaners.
Frank
73 Duster - Race Car
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
Users browsing this forum: Bing [Bot] and 46 guests
