It is currently Mon Jun 15, 2026 4:31 am
Post new topic  Reply to topic  [ 86 posts ]  Go to page Previous 1 2 3 4 5 6
PostPosted: Fri Jan 08, 2010 9:04 pm
Nice, so long as the geometry between your repair and the original pump are is identical. In other words, nice, so long as the hole you made is in the same spot as the hole in the original plastic arm.
I like people who are creative enough to fix their own problems.
Thanx. :mrgreen: :mrgreen:
68 225 Dart "life under the hood, is the life for me" -By Me
PostPosted: Sat Jan 09, 2010 7:46 am
X2
72 dart acquired 12/08 /6,holley2b, mopar perf intake, mopar perf header, cam, built motor,904 finally re-installed, 8.75....still needs sorting out.
99 dakota 318 5 speed reg cab picked up 9/09; Trans finally fixed! woohoo!
PostPosted: Sat Jan 09, 2010 5:40 pm
http://www.youtube.com/watch?v=xrpPbui37Dk
PostPosted: Sat Jan 09, 2010 6:08 pm
Now I got ya. Its a slant 6 what more do u need. Don't tell my wife I said that. Lol :shock:
PostPosted: Thu Jan 14, 2010 12:07 am
I been running my 225 with out air filter, cause of oil coming up the breather hose to the carb. do u guys know why? Thanx.
PostPosted: Thu Jan 14, 2010 1:24 pm
Don't do that. You're basically sandblasting the cylinders and when you remove the head, don't be surprised to see a good sized wear ridge in each cylinder. Sounds like a pcv problem. replace the pcv valve and make sure the hose to the carb, and the carb itself isn't plugged up.
PostPosted: Thu Jan 14, 2010 6:55 pm
I thought the same thing, changed the pcv still same problem.
PostPosted: Thu Jan 14, 2010 7:08 pm
Excessive blowby possibly from worn rings or valve guides. Do a compression check or a leakdown test if you want to get fancy.
PostPosted: Mon Jan 18, 2010 7:56 pm
I fixed the pump lever myself here's some pics.
it works grate! Thanks for everything guys.
Good deal. The guy asking $15 for that was out of his mind. I wouldn't pay more than $2 for one.
PostPosted: Wed Jan 20, 2010 10:36 pm
How about for this custom piece? So I can get it Patten. Its metal no more broken acceleration pump levers. :lol:
PostPosted: Thu Jan 21, 2010 1:43 am
This one time i was touring with over 100 classic cars and a nut on the back of my 1920 throttle linkage loosened off when i was accelerating through the parking lot, it was like the pedal was stuck down :p Luckily i reacted quickly and killed the ignition but hopefully that arm doesn't snap at a funny time.
Users browsing this forum: Amazon [Bot], Bing [Bot], Google [Bot] and 2 guests
