It is currently Wed Oct 14, 2026 1:17 am
Post new topic  Reply to topic  [ 178 posts ]  Go to page 1 2 3 4 5 … 12 Next
PostPosted: Thu Feb 18, 2010 8:13 pm
Hello all this is my first stab a this style so let me know if we are on the right track.
We will finish the install soon, stock kick down linkage, carb, choke pod, power steering, ect ect. Thank you for your input Don.
'72 Image Duster /6 with turbo build up
'03 Ram 2500 4x4 w/HEMI 5sp 4:10 posi
My Twister Page
Last edited by Mister Twister on Sun Jul 04, 2010 8:12 pm, edited 1 time in total.
PostPosted: Thu Feb 18, 2010 8:29 pm
Much better! Could use a longer, smaller diameter collector, but this is a big improvement.
PostPosted: Thu Feb 18, 2010 9:11 pm
Much nicer! This one might be fun.....but you should incorporate a collector......a nice smooth transition is important!
PostPosted: Thu Feb 18, 2010 10:24 pm
ALOT better,I agree with the others on the collector.You are listening very well.My hats off to you for the time and effort you are putting into this,Thanks.Guzzi Mark
PostPosted: Fri Feb 19, 2010 4:38 am
Thanks Joshua. How much longer and what size do you think the collector should be to help the slant class :?:
My Twister Page
PostPosted: Fri Feb 19, 2010 4:59 am
Ted this is alot of fun, :D We have been checking on collectors, I will most likley build my own, the prices are crazy for these already made. I am trying to keep price down for all of us. The reason for them being so short is that they are welded from the inside, just looks a little better I think. These are not set in stone and will change a little I'm sure, do to input. Choke mounting will be installed today!! Talk to you later Don. 8) Image
My Twister Page
PostPosted: Fri Feb 19, 2010 5:17 am
These kind words from some of the top slanters is making me very happy. :D I have ordered more flanges, that set is for testing and I should be doing this soon. :idea: I will also contact Charlie around Ocala he is not that far from us, we would like to see fitment in early A bodys and the 170 for adjustments we may need. Talk to yall soon Don.
My Twister Page
PostPosted: Fri Feb 19, 2010 5:24 am
Are those 3" collectors, or bigger? 3" would be nice just for parts availability. These look quite nice and may be better than the Clifford shorties when you get a collector sorted out.
Keep up the good work!
PostPosted: Fri Feb 19, 2010 5:38 am
Hello Dart270 yes these are standard 3" collectors. If you have a smooth shrinking pipe let say 3" to 2" 8" long connected to these, is that not the same as a longer collector? Just asking for my info :? Don
My Twister Page
PostPosted: Fri Feb 19, 2010 4:34 pm
I think that the answer is "yes" as most typical headers are designed this way.
Your headers could be good for people who wanted to choose their collector length to suit their build.
Could you give us a pic of where the pipes come together at the flange?
72 dart acquired 12/08 /6,holley2b, mopar perf intake, mopar perf header, cam, built motor,904 finally re-installed, 8.75....still needs sorting out.
99 dakota 318 5 speed reg cab picked up 9/09; Trans finally fixed! woohoo!
PostPosted: Sat Feb 20, 2010 8:59 am
Would you be willing to substitute a T3 turbo flange at the end, after the collector?
How about stainless or ceramic coating as options?
What kind of price are you shooting for?
PostPosted: Sat Feb 20, 2010 7:05 pm
Personally, I think 3" collectors are the way to go anyway.
You may want to get ahold of some other types of manifolds to make sure your pipes'll fit those (at least Offy and Clifford 4bbl and maybe Offy 2X1?).
Also, let me know if you you would be interested in doing a single-outlet turbo manifold, either one off or to produce.
Keep it up!
PostPosted: Sat Feb 20, 2010 8:50 pm
Scroll down about 1/4 of the way.
http://www.headersbyed.com/_collect.htm
I think your collector should look like these.
I think I remember using about a 15 degree merge angle until you get down to the size of the collector you want.
If you want to get fancy have a triangular spike in the middle...
PostPosted: Sun Feb 21, 2010 4:27 am
Hello all. This weekend is packed full of work for me, thanks for all the info. Wow sometime all we need is the right pic to make the light go on. I did post the first choke pod, started with the 1bbl and will be doing the 2bbl soon. Not enough time this morning to respond to all's response I will be back in here tonight or in the morning. See you soon Don.
Have a good day :)
My Twister Page
PostPosted: Sun Feb 21, 2010 5:01 pm
I'm with Greg on this one. Would you be willing to make them to sell after you perfect your design? :D If you offer a reasonable price, then you could sign me up for a pair. 8)
Users browsing this forum: No registered users and 205 guests
