It is currently Thu Nov 26, 2026 2:57 am
PostPosted: Sat Mar 13, 2010 2:48 pm
My friend is installing the aftermarket AC unit in his 73 Dart with SL-6.
The instructions indicate to use a "slim line" fan.
His stock fan doesn't fit or clear.
Anyone done this swap & found such a fan?
PostPosted: Sat Mar 13, 2010 3:24 pm
I am guessing the fan clearance issue is that the trailing edge of the fan would hit the A/C compressor -- is right? If so, by far the cleanest and best option is to get one of Charrlie_S' compressor mount kits, which is far better thought out than what Classic sells.
PostPosted: Sat Mar 13, 2010 6:28 pm
That is why I designed this compressor mount. Installing A/C in an "A" body was always a pain in the tookis.
http://www.slantsix.org/forum/viewtopic.php?t=38778
