It is currently Fri Jul 17, 2026 9:22 am
PostPosted: Thu Jul 08, 2010 6:09 am
Does anyone have the p/n and specs (temp range switch is designed to open at) for the radiator mounted thermo switch for the EGR system on a 78 D100 /6 with 3 spd std trans? My switch appears to be open all of the time and I can't hook up my EGR system because it won't run well at all when cold. NAPA has several listed, but all have different temp ranges, with some as low as 68 degrees. Thanks-Mike
Good gun control is hitting your target repeatedly
PostPosted: Thu Jul 08, 2010 7:19 pm
Site Admin
AIRTEX / WELLS Part # 7P1078 {#3870654, 3879707, E938}
(150 deg.F - Natural); 3870654, 3879707
http://www.rockauto.com/catalog/moreinfo.php?pk=943202
AIRTEX / WELLS Part # 7P1080 {#3837622, 551472, 560694, E932}
(Blue -- 2 Port); 3837622, 4049276
http://www.rockauto.com/catalog/moreinfo.php?pk=945685
AIRTEX / WELLS Part # 7P1081 {#3870549, 3879736, E955}
w/Yellow or Black (2 Port); 3879736
http://www.rockauto.com/catalog/moreinfo.php?pk=941976
Those are the ones on Rockauto.
150 degrees sounds about right. Engine should be up to temperature before EGR is introduced.
:D
CJ
 Post subject: Hmmm...
PostPosted: Thu Jul 08, 2010 9:11 pm
In that era of head i've only encountered blue ( 76-78 ), and yellow (1977+)
Interesting.
PostPosted: Thu Jul 08, 2010 9:30 pm
Site Admin
Come to think of it, I may have grabbed that off the '74 list. Reflex I guess. Just search on your year, that should get the right one.
Yeah, I drive a '74... :roll:
CJ
PostPosted: Fri Jul 09, 2010 3:10 am
I've been no the local NAPA, the only only one that they show is rated to open between 45 and 72 degrees (blue). I was under the impression that this should only open when up to operating temperature. I want to get this hooked back up to see if it eliminates the pinging problem I've been having. I've done numerous carb tunings, replaced springs in the distributor, messed with timing settings,checked for vac leaks, etc. Mike
PostPosted: Fri Jul 09, 2010 5:05 am
Site Admin
Try another parts store. 72 Celsius maybe?
CJ
PostPosted: Fri Jul 09, 2010 11:59 am
72C = 162F
Users browsing this forum: Amazon [Bot], Bing [Bot], Google [Bot] and 3 guests
