It is currently Fri May 22, 2026 3:27 am
 Post subject: Elusive oil leak
PostPosted: Sat Aug 21, 2010 6:13 pm
I have a 85 engine that loses 10w30 oil at a rate of 1qt per 1500 miles. The engine has well over 100k on it, it has relatively new front main seal new valve cover gasket/head gasket and valve seals. The exhaust has no blue smoke and I do not see any engine oil drips on the engine. I am for a loss. Can any one offer any suggestions.
Thanks for any help
85 d-100 HEI 2BBl
06 Toyota Corrola
PostPosted: Sat Aug 21, 2010 6:57 pm
At 1 qt per 1500 miles you won't notice any blue smoke........
It's most likely burning it off, and if the plugs don't get fouled, I wouldn't worry about it.....
PostPosted: Sat Aug 21, 2010 7:07 pm
Image Sorreeee...
Aspenized
PostPosted: Sat Aug 21, 2010 7:16 pm
One quart ever 1500 miles on that old an engine? You have high standards Sir. I myself would be perfectly happy.
PostPosted: Sat Aug 21, 2010 8:59 pm
Unless my engines use more than 1 quart every 800 miles, I am quite happy.
PostPosted: Sun Aug 22, 2010 5:23 am
Back in the day, when these cars were new, the factory considered 1 qt per 1,000 mile acceptable.
PostPosted: Sun Aug 22, 2010 2:26 pm
They still do...........
PostPosted: Mon Aug 23, 2010 9:17 am
You may want to check the calibration of your dipstick... no joke.
On my 66 Dart wagon, if I fill it to the "Full" mark, on the dipstick, it will quickly drop back down to the add line, then stay there.
I later found-out that when at the full mark, there are 6 quarts in the engine. :? :roll:
These days, I run it at the add line and it "uses" way less oil.
PostPosted: Mon Aug 23, 2010 10:12 am
OK, So it looks like this is not as big a deal as I thought. thanks for the reassurance.
85 d-100 HEI 2BBl
06 Toyota Corrola
 Post subject: Elusive OIl Leak
PostPosted: Mon Aug 23, 2010 12:10 pm
Your engine is perfect. Mine on the other hand loses about a quart every 100 miles, im pretty sure its leaking but i dont get many drips on the driveway, must be accentuated under load. I was thinking worn valve guides but there is no blue smoke on startup.
1973 Plymouth Valiant 225 Torqueflite 904
