It is currently Tue Nov 24, 2026 4:19 pm
PostPosted: Wed Sep 29, 2010 12:28 am
Hey all,
Strange thing happened the other day. I went out to start Delilah (my 71 Dodge Dart) and see how she was running and she would barely stay running. The problem eventually got worse and worse until I decided to start changing some things. I changed the coil out, the points, regapped, condenser, used two different sets of plug wires, inspected dizzy nylon gear (looks great). I know that I am getting fuel, when I pulled the plugs they were wet and the main jet + accel pump squirt were fine. I also checked the distributor rotor for play and verified that it was turning without slack in sync with the crank.
Now it sounds to me like something that happened on my "i'm too small to ride but really fun" 84 XR100. On the XR, like the Dart, it was backfiring through the carburetor when it was way out of time, and thats when I found out that the XR's timing chain jumped a few teeth.
This is also what I think mysteriously happened to Delilah overnight, gremlins jumped my timing chain a few teeth.
Strangely enough, before it wouldnt start it did sound like the starter was spinning something but not engaging. After a few cranks it sounded ok and my attention was diverted to the rough idle.
Any ideas? Or is it much simpler than this? :idea:
The only way you can ever really break something beyond repair is to give up trying to fix it.
PostPosted: Wed Sep 29, 2010 1:11 am
I'll start off by asking how long you've had the car?
The only issue is a rough idle, and it gets worse as the car warms up?
When was the last time the engine was running?
Checklist (easy to difficult):
-choke operation
-idle speed
-timing
-idle mixture
-valve lash
-timing chain and gears
-rebuild carb (only if you suspect dirt in the carb, due to it sitting for extended periods)
'66 Dodge Dart
PostPosted: Wed Sep 29, 2010 4:30 am
S\ant6,
First off welcome to the board, you will find commonly discussed issues under the various “Stickysâ€￾ at the top of each page of the forum that are full of information.
Secondly, if you don’t have a copy of the “Factory Service Manualâ€￾, cellulose or digital, we recommend you get a copy as it is the one most important tool you can have on hand to understand & service your Dart..
Now this run ability problem you’re having:
You started a cold engine, and its idle became more degraded as it warmed up, and you later discovered wet plugs, correct?
The engine is getting enough fuel, wet plugs indicate perhaps a little too much fuel. I would check the see if the choke is pulling off after a cold start. If the choke is not opening for whatever reason: vacuum pull-off; bi metal spring that controls opening & closing by engine heat, or binding linkage for any maladjustment.
Another item to check would be the float level of the fuel bowl in the carburetor to see if the float has sunk, or needle valve is not sealing properly allowing raw fuel to be dumped down the manifold. This is where your “Factory Service Manualâ€￾ would be helpful, as it has the float setting spec. But, don’t despair, check the “Engine Stickyâ€￾ for carburetor articles covering your carburetor’s adjustments here on this page.
I don’t think your timing chain has jumped, but now that you have had the distributor out & in, you need to reestablish static timing. This is easy done by locating TDC of number one cylinder (closest to radiator), and checking the position of timing mark on crank pulley, and the rotor button; which should be pointing between 4 & 5 o’clock at #1 plug wire contact.
You have eliminated the electrical half of the equation, most likely needlessly, by just pulling the trigger on that shot gun.
Bill
PostPosted: Wed Sep 29, 2010 9:39 pm
Sorry, not previously much of a forum poster, so forgive my inability to properly explain myself. Thanks all for being patient. Here goes.
The night before the problems it ran fine, with its typical flat spot when revved that I have not remedied yet. Curb idle was good, with a slight miss here and there, but barely discernable. Fast idle was set as well, and choke was operating as it should, opening slowly while the engine warms and moves the heat riser.
The issue is that it went from a great idle in gear and in P/N, to acting like it was running off of 4 or 5 cylinders the very next morning. It almost seemed like something had plugged one of my intake runners, as timing had not changed at all since I started her the night before.
She no longer starts or idles, only backfires out of the carb every 3 or 4 revolutions. Since I removed the distributor, I did time it on the #1 cylinder at TDC and positioned the rotor button correctly. Previous timing check indicated a factory 0 TDC with the vacuum advance plugged.
I've only had the car for 2 months now, bought her for 500 bucks, replaced the fuel pump and filter, and she ran great (save for the flat spot). Now she doesnt start, and before she stopped starting altogether, it would take mashing the pedal to the floor to get her to fire. Main jet is clean and bowl was full of fuel, and the wet spark plugs was after lots of turning over and not firing.
When I timed off of the #1, is it possible I timed her 180 degrees out? Still doesnt explain why she doesn't start as I made no adjustments to timing the day before. I did blow out as many passages as I could (idle mix screw, vacuum advance nozzle at base of carb, accel pump jet area, etc with an air compressor. Befuddled.
 Post subject: and...
PostPosted: Wed Sep 29, 2010 9:42 pm
I have NOT made any valve adjustments as of yet, but I was thinking that the brake cleaner that I use to clean the carb could have burned some valves? Or is that too "chicken little the sky is falling"?
PostPosted: Wed Sep 29, 2010 10:04 pm
The real danger is that you can make chlorine gas by burning brake cleaner. :shock: It's a real bad neurotoxin and you can die from breathing a little bit. Maybe Gum-out or a similar product would be a better choice. I doubt it burned a valve, though.
 Post subject: Good call Slantfin
PostPosted: Wed Sep 29, 2010 10:11 pm
The good thing about the exhaust when it is burning brake cleaner is that its very, very irritating to the sinuses w/o even breathing it. I did notice that whatever gas that was, it wasnt good to breathe. Ill use gumout from here on out :)
PostPosted: Wed Sep 29, 2010 11:09 pm
Sounds like you are having quite the adventure!
It is very possible (and likely) that you positioned the distributor incorrectly (even 1 tooth makes a huge difference). Also note, 4 stroke engines see TDC twice. So make sure and check to see if the timing mark indicates TDC, if not then you are 180° off. Try again.
Once you get it running, do a valve lash adjustment (see the engine FAQ links), and make sure the carb is tuned (specifically float level and idle mixture) correctly. You'll notice the difference when starting. ;)
As for the original issue... no clue, check back in after you follow the above. Let us know what symtoms are left. I'm interested in the flat spot you spoke of, possibly gone after you do the valve lash and idle mixture.
'66 Dodge Dart
PostPosted: Fri Oct 01, 2010 6:00 am
So fellas, after going over the ignition a million different times, I decided today to remove the plugs in order to a. check spark at plug, b. time again off of #1 cylinder and c. check compression. Before I checked compression I decided to remove the valve cover and check valve action. To my dismay, the exhaust valve moved and the intake did not. 3 minutes later, the valve cover bolts (which were finger tight) were out and the cover was off, revealing cylinders 1, 4, 5 and 6 pushrods were just hanging out, not even close to a rocker. Number two is loose also, and the valve train is nasty.
Sometimes it takes a while, but they'll eventually tell you what they need. Thanks all for the help, ill let you guys know when I get er fixed. [/img]
PostPosted: Fri Oct 01, 2010 9:24 am
I guess it's a testament to the slant however, that it ever started at all under those conditions.
1954 Ford, Tudor Mainline
1976 Plymouth Valiant, 4 door
www.automotive-ninja.com
PostPosted: Fri Oct 01, 2010 9:36 am
I drove home with an ignition rotor that the center contact had broken off of. It ran like crap, but got me home!
PostPosted: Mon Oct 04, 2010 7:08 pm
Hey, me too! The center button was completely ground/broken off of my dist. cap and only making contact between the very backside edge of the rotor contact and 1/16" of the outer brass installation ring in the middle of the cap! I still made it home that night though. Very surprised to see that the next day :shock:
'68signet
"Living analog in the digital age."
Users browsing this forum: Amazon [Bot], Google [Bot] and 5 guests
