It is currently Tue Nov 17, 2026 11:12 am
 Post subject: Shift cables
PostPosted: Mon Oct 11, 2010 12:04 pm
I bought a 1965 904 tranny and now I need to find a shift cable for it, but there are different shift cables available, column shift and console shift, are those cables different in any other way then the length of the cable ?
 Post subject: -
PostPosted: Mon Oct 11, 2010 9:28 pm
I don't know too much about pre-67 transmissions,but I think the valve body in the trans was even different,push button vs steering column or consol shift.
PostPosted: Mon Oct 11, 2010 10:25 pm
6 Pack Dart
I don't think the valve bodies are different, maybe just the cables :?:
Does the transmission have any arms or levers on the exterior?
Richard
PostPosted: Tue Oct 12, 2010 9:00 am
The transmission & valve body is the same (65 only, 6 detent positions) but the cables / linkage is different. (the shifter mounting ends change)
Cables made for one assembly can not be used on the other.
What is your need... cables for a 65 column?
PostPosted: Tue Oct 12, 2010 8:46 pm
someone is selling a 65 tranny at FABO---- maybe they would sell you just the cables ,Lawrence
