It is currently Thu Nov 12, 2026 10:53 am
 Post subject: transmission output?
PostPosted: Sun Jan 23, 2011 8:59 pm
OK this can be con fusing i have a slip in drive shaft on my 67 slant six for my trans. well now i got a 65 transmission and its got a bolt up disk for the output and i am completely lost, i do not know transmissions. HELP TIPS NOW!!
 Post subject: Re: transmission output?
PostPosted: Sun Jan 23, 2011 9:15 pm
HELP TIPS NOW!!
I didn't hear a please.
PostPosted: Mon Jan 24, 2011 2:38 am
First off, what car? The 67 Coronet? You will need to find (or have one made) a driveshaft, with the flange that is from a car with the same wheelbase. But you will also have a problem with the shift "linkage", and possibly the speedo cable, when putting the 65 trans into a 67 car. The car has a mechanical rod linkage, while the trans has cables for shifting and the parking pawl. Your best bet is to find a 66 or 67 trans, to install.
PostPosted: Mon Jan 24, 2011 3:59 am
Also, when a transmission has a output flange rather than a slip-joint, the driveshaft needs to have the slip-joint..................
PostPosted: Mon Jan 24, 2011 8:25 am
HERE is one approach to converting to a cross-and-roller U-joint.
PostPosted: Mon Jan 24, 2011 9:46 am
Yep, that's my 66 Cuda
