It is currently Mon Dec 02, 2024 6:58 am
 Post subject: air cleaner question,
PostPosted: Mon Jan 31, 2011 11:28 am
hi, so i found an air cleaner off of a 1980 dodge van with a 318 and a 2 barrel carb, so!
will this air cleaner fit, without modification in my 1973 dodgevan b200, with a 2 barrel as im going the super six on it and need an air cleaner.
any help is greatly appreciated!
PostPosted: Mon Jan 31, 2011 12:24 pm
No. The Super Six air cleaner for vans is van specific. Oh, I see Reed already answered your question. http://slantsix.org/forum/viewtopic.php ... ner#301956
PostPosted: Mon Jan 31, 2011 12:42 pm
Like I said, your best bet is to cut and weld the portion of the two barrel air cleaner that fits around the carb into the base of the one barrel air cleaner. Be sure to keep the new welded in section centered under the hole in the lid for the air cleaner nut stud.
You can use the 318 air cleaner base portion that you have already purchased, but I highly recommend you get a van one barrel slant six air cleaner off of an 80s era van. This gives you the provision for hot and cold air intake, both of which are good improvements.
PostPosted: Mon Jan 31, 2011 5:14 pm
ok cool thats what i thought. and i already have the two to be modified, i just thought id ask. ill continue on my merry way!
Users browsing this forum: Bing [Bot] and 28 guests
