It is currently Mon Dec 02, 2024 4:47 pm
 Post subject: Numbers
PostPosted: Mon Jan 31, 2011 1:21 am
Hi,
Looking at my engine block at these numbers what can you guys tell me...?
Engine is red.
08026:
248343015
I've been looking on the internet and using search just hoping you have some extra info. like. My engine block is titanium or something so it's worth alot:P
PostPosted: Mon Jan 31, 2011 2:29 am
or something :) , either it's cast iron or an aluminum block.
Where did you find the numbers ? 24... would suggest a block after 62 (the aluminum block was made from 1960 to 1962) and they made around 45000 of them, but I might be 100% wrong here.
PostPosted: Mon Jan 31, 2011 2:39 am
On the engine block, just under where the manifolds are, I'd post a photo but because of the headders you can't see it.
There is - in there somewhere, but I can't see it now it's too late I'll add it later.
PostPosted: Mon Jan 31, 2011 2:58 am
Ok, in 1960-1962 it should be on the left side of the block, 63 on they put it on the right side front just below the head, so I guess it could be an aluminum block then.
PostPosted: Mon Jan 31, 2011 6:30 am
look under # 1 plug...top of block ...there are stamped numbers
PostPosted: Mon Jan 31, 2011 8:51 am
248343015 is really 2463430-15? (look at it closer)
This should be a 60-67 "three freeze plug" cast iron SL6 block... made form casting pattern "#15", which is somewhat later in the production run of these blocks.
The stamping on the corner of the deck will tell us the year it was made.
http://www.slantsix.org/articles/dutra- ... blocks.htm
PostPosted: Mon Jan 31, 2011 12:27 pm
Yes doc you are correct it is a 6 and not an 8.
The other number is CC 225 10 12, what year does that mean it was made in...? and I'm guessing it means I have a cast Iron block with a aluminium head?
PostPosted: Mon Jan 31, 2011 3:52 pm
Where did you get the motor from ?
I didn't think we had aluminium heads on our Australian slant 6's.
DRIVE IT,DON'T HIDE IT
PostPosted: Tue Feb 01, 2011 4:24 am
Yeah I'm not sure, hoping someone can tell me from these numbers :/
