It is currently Sat May 23, 2026 7:39 am
PostPosted: Thu Feb 03, 2011 7:57 am
Hi folks,
I am going to upgrade my single master cylinder on a 64 valiant to a dual master. What year of car makes the easiest transition. I know there is replumbing to be done but mostly I just need the simplest change over. Any help is appreciated...thanks Mark
If only I had the time to do what I want to do instead of what I have to do!
PostPosted: Thu Feb 03, 2011 5:02 pm
Depending on where you buy your parts most MCs are listed for what the do i.e. 4 wheel manual drum or power front disk rear drum. Just get the one that matches your set up. I went with manual KH front disk and rear drums so that was the master I went with and you'll need a proportioning valve too. Check out Rock auto...
'72 4 dr Dart
'63 4 dr Dart
PostPosted: Tue Mar 15, 2011 12:34 am
OK, I'm a month late here... so I assume you've discovered this article by now. But just in case not...
http://earlycuda.org/tech/dualmaster.htm
- Erik
 Post subject: brakes
PostPosted: Wed Mar 16, 2011 11:09 am
Erik,
Thanks so much. With all the other things im doing with the car I had not gotten around to this yet. Your article will make it much easier...Mark
Users browsing this forum: No registered users and 18 guests
