It is currently Mon Nov 16, 2026 10:38 pm
Post new topic  Reply to topic  [ 18 posts ]  Go to page Previous 1 2
PostPosted: Sun Mar 13, 2011 1:44 pm
They look like they would clear the remote oil filter set-up we have on our Australian slant sixes,which is at the front on the left hand side of the engine.
DRIVE IT,DON'T HIDE IT
PostPosted: Sun Mar 13, 2011 2:37 pm
More info:
Yes, they were made in Australia (still don't know when or by whom) and will fit at least '63-'69 (and possibly also '60-'62) A-bodies with RH-drive, also trucks and vans. Likely also B- and/or C-bodies, not confirmed.
Primary pipes are 1½". Rectangular flange ports are ~1.128" × 1.388". Collector OD is 2½". Tube wall thickness is 0.069" (which is between 15ga and 16ga).
Front collector has a small dent, see photos. Easy with a ball peen hammer, even easier with a pipe expander.
Rear collector for some strange reason is swaged to something a bit smaller than the collector's basic 2½" OD. A connector adaptor could easily be slipped over these and welded to the pipes, then about ½" sliced off the collector to undo this OD reduction.
PostPosted: Tue Mar 15, 2011 1:33 am
First $360; please send me a PM.
Users browsing this forum: Ahrefs [Bot], DuckDuckGo [Bot] and 2 guests
