It is currently Sun Jun 21, 2026 10:52 am
 Post subject: power pipe DC
PostPosted: Wed Apr 20, 2011 5:58 pm
Has anyone run these? What do they sound like? Are they better than the iron manifold?
I am converting to propane and do not want manifold heat, it's a "two-fer" or maybe 'threefer' because it removes the heat, may provide some performance increase and should sound better, too.
Any experience? I emailed the seller, but haven't gotten an answer yet (few hours ago).
'81 W150 on Propane... Oversize valves, Oregon Camshaft cam, 10:5 static CR, Distributorless ignition, megajolt timing controller, PowerTrax lockers.
PostPosted: Wed Apr 20, 2011 6:44 pm
i found the same stuff recently and got all excited. but look at it - it's 90' angles. as pointed out by a few chaps here - it aint gonna flow that good.
i then found a beaut on FABO about modifying a stock cast-iron manifold by chopping out the centre heatbox section and converting to a dual-output.
they guy on FABO who did it is 'waggin'.
i've now got an extra exhaust manifold which i'm going to start chopping up - aiming for dual 2" running side-by-side down the LHS of the car (following stock routing)
it should look ripper with my speco dual Carter BBS intake.
here's a pic of waggin's work:
(image courtesy of FABO - http://www.forabodiesonly.com/mopar/sho ... hp?t=36378)
waggin, the guy on FABO who was responsible for the above set-up, reports the following:
"the early (1966 and older) exhaust manifolds are made of cast steel (can be welded with a mig welder) 85 chevy drivers side manifolds from a monte carlo are the pieces I used to make the downpipes. I ran 2" true dual exhaust to the rear of the car I was very happy with the performance and the sound,don't know what the performance gain was but it sounded great,and i have over three years service as a daily driver on them and no problems,they are on bruces car now as I have installed a v-8 and four speed..........."
Chris
The Wayfarers
six 'n out
PostPosted: Wed Apr 20, 2011 6:48 pm
Site Admin
The power pipe has a thread lurking around here someplace.
Dutra Duals, and Dual Dutra duals are the modified factory manifolds, and new casting(s) created by Doug Dutra. A quick search here will net lots of hits.
I run Dual Dutra Duals on my Valiant to good effect. :D
CJ
PostPosted: Wed Apr 20, 2011 6:50 pm
Read here and here and here.
PostPosted: Wed Apr 20, 2011 7:12 pm
CJ
I'd love to, but that's just totally outside of my budget now.
PostPosted: Wed Apr 20, 2011 7:45 pm
yeah. for me, dutra duals price themselves out due to the cost of shipping to australia.
hence the DIY approach of chopping up a stock manifold appeals . . .
Chris
The Wayfarers
six 'n out
PostPosted: Wed Apr 20, 2011 7:56 pm
But I have no shop, no means of doing that.
If I had the tools, I would have simply done my own.
PostPosted: Wed Apr 20, 2011 8:22 pm
i have no shop either. i'm taking the stock exhaust up to my local muffler guy with a 'no rush - what can you do?" type of spec. then i'll paint them up with high-temp to match stock.
it'll still :
a) be cheaper than a set of long-runner extractors
b) look better ('stockish') with my speco dual intake
c) flow better than the stock single-outlet
d) be different to everybody else
all good things!
chris.
Chris
The Wayfarers
six 'n out
