It is currently Fri May 08, 2026 12:14 pm
 Post subject: stuck brake drum
PostPosted: Sun May 08, 2011 7:28 pm
i could use some help. i have a 67 dodge A100 van. i am trying to remove the drivers side frt brake drum. There are no pushers holes on the drum it self. i have loosened the pads up as much as possible and cant find the lever to release it from the inside. whats the trick? thanks for any help i can get.
PostPosted: Sun May 08, 2011 7:54 pm
You have the outer wheel bearing out correct?
PostPosted: Sun May 08, 2011 8:01 pm
i know this is going to sound stupid, please dont laugh to hard. it sounds like i need to remove the cotter pin, large nut, and bearing. if that is the case, somebody needs to rewrite the 40 year old manuel ive got.
PostPosted: Sun May 08, 2011 8:10 pm
Yeah, the dust cap, cotter pin, nut, washer and outer bearing all have to come out. The original drums are swedged to the hub and don't slip off the hub.
PostPosted: Sun May 08, 2011 8:13 pm
i thought it would slip over all that. that was the bit of info i needed. thanks for the help.
PostPosted: Sun May 08, 2011 8:18 pm
No laughing, just personally I never liked that chrysler's front drums were secured to the hubs ( I generally don't like front drums period).
63 Valiant Wagon
225 - 4 bbl
PostPosted: Mon May 09, 2011 5:29 am
Just so you don’t feel left out, the early Chrysler KH disk brakes are also firmly attached to hubs as well… Like wise for KH used on early Mustangs.
PostPosted: Mon May 09, 2011 11:11 pm
With the KH discs there was no swedging. The studs press fit into the hub - the back shoulder holds the rotor in.
