It is currently Sat Oct 05, 2024 7:34 pm
PostPosted: Tue Sep 16, 2003 9:31 am
Good day gentlemen, I am visiting your board from the P-15 D-24 site I commonly haunt, as I have some questions regarding what I believe is a Carter BBS carburetor. I purchased a used dual carb set up on a fenton manifold. This set up came with the carbs, and will be mounted on my 46 Plymouth flathead 6 along with an Edmunds Finned aluminum head. I have been told by a NAPA counter man that the carbs are 60's vintage units common to slant 6 stock applications. While disasembling the rear carb for cleaning, i was suprised to have two check balls fall into my hand when i inverted the float bowl. I know one goes under the accelorator pump, I am guessing the other goes into the casting under where the float hinge locates. I say guessing because when I disasembled the 2nd carb, it only had one check ball and it is captured by a brass fitting in the accelorator pump chamber. I have a picture, but don't know how to post it here. If any of your are intimately familiar with the BBS 3512 s carb, please respond here or to my email. Thanks. I have enjoyed reading some of your post here, and this will probably become one of the sites I visit frequently. MOPARS ARE COOL, 6's rule.
Thanks Greg G
PostPosted: Tue Sep 16, 2003 11:48 am
I believe the large one goes under the accelerator pump plunger and the small one goes in the pump discharge hole which is adjacent to the carb bore. Sometimes the latter sticks in it's spot, so check your second carb and make sure it's not just frozen in place. I'm not a BBS expert, but they are very similar to a BBD which I know fairly well.
"DW"
If it ain't broke, fix it!
PostPosted: Tue Sep 16, 2003 12:46 pm
You say discharge hole, wouldn't it get pushed out, and into the engine by the jet of gas??? Is there a way to post pictures to this site?
Check this picture;
http://photo.starblvd.net/~gonygl/1-1-4 ... 213F668882[/img][/url]
PostPosted: Tue Sep 16, 2003 8:45 pm
The other ball goes to that lower place You have marked in your pic (under the accelorator pump) and other goes to that hole which is lowest left in your pic.
Joug
Sorry, my english is not very good
PostPosted: Tue Sep 16, 2003 9:43 pm
I rebuilt mine, but it was my first. Here is the pic I went by. I hope it helps.
http://www.carburetorfactory.com/expvw02.html
PostPosted: Wed Sep 17, 2003 8:25 am
Gentlemen, thanks for your input. I now have what I need to proceed. Appreciate you somewhat slated views (30 degrees I believe) MOPARS ARE COOL, 6's Rule.
PostPosted: Wed Sep 17, 2003 9:35 am
We all seem to have that leaning here, don't we? Just a bit off kilter...
" D
W"
 Post subject: BBS Carbs
PostPosted: Wed Sep 17, 2003 9:48 am
Your carb is from 1960-1963 Dodge/Plymouth 170/225 with standard shift.
 Post subject: Re: BBS Carbs
PostPosted: Wed Sep 17, 2003 9:59 am
Dang, there's a couple old homely Valiants sitting around uselessly with no carbs! Better give 'em back, greg g! ;)
"DW"
PostPosted: Wed Sep 17, 2003 10:13 am
Just wanted to let you guys know E-bay has a neat little 63 Dart Convertable listed. It has a 4bbl and tubular headers. Suffered a slight engine fire, but I'm sure you folks could deal with that.
Greg G
PostPosted: Thu Sep 18, 2003 12:20 am
I'd rather stick myself in the soft parts with a red-hot poker than buy a car off of ebay! :shock:
"DW"
Users browsing this forum: Ahrefs [Bot], Amazon [Bot], Semrush [Bot] and 24 guests
