It is currently Thu Oct 08, 2026 1:20 am
 Post subject: No oil pressure
PostPosted: Tue Dec 27, 2011 4:44 pm
Fired new rebuilt six no oil pressure pulled valve cover no oil splash pulled filter off and it looked dry. Can I get the pump out while it's still in the car(1969 dart) or is there something else I could do first. Also there were a couple drips of water by the number 1 and 6 exhaust bolts
"Courage is being scared to death-but saddling up anyways" John Wayne
PostPosted: Tue Dec 27, 2011 4:51 pm
6 Pack Dart
Remove filter and pour some oil down the stand pipe and the hole next to the pipe. you need to put some sealer on the threads of the leaking bolts.
Richard
PostPosted: Tue Dec 27, 2011 4:58 pm
Richard
thanks I will try the pouring of oil. is there water behind the all the exhaust bolts ? I just screwed new studs into the head
PostPosted: Tue Dec 27, 2011 5:06 pm
on a new motor, I would pull the plugs, ( pull the coil wire to) and crank the motor, 10 to 15 seconds at a time until you see oil pressure before starting it..
PostPosted: Wed Dec 28, 2011 10:53 am
still no pressure going to drain oil and see if there's a pick up :( if there is guess im going to have to drop the pan and see if its plugged
PostPosted: Wed Dec 28, 2011 11:33 am
I did that with my motor put the pan on and thankfully I realized I had forgotten the pickup before I put it in the car.
64 dart GT /225
...........____ .
...._n_.[____].
.....L\....\......
.......\____\....
PostPosted: Thu Dec 29, 2011 7:43 pm
Well pulled the motor and found there was no pickup,off to the wreckers tomorrow thanks to everyone for the help trying to solve this . Not the experience I wanted for my first six experiment . Things should be better tomorrow if I can get it back in the car.
PostPosted: Fri Dec 30, 2011 12:39 am
So why not use the one YOU left out? :lol:
regards,Rod :D
PostPosted: Fri Dec 30, 2011 7:56 am
regards,Rod :D
bought rebuild with all the tin on, thats why :)
PostPosted: Fri Dec 30, 2011 11:00 am
regards,Rod :D
Well, that's a reasonable excuse. :lol:
regards,Rod :lol:
PostPosted: Sun Jan 01, 2012 10:44 am
regards,Rod :D
We bought rebuild with all the tin on, thats why :)
I would be worried about that engine...
Re-check everything... the builder may have "forgot" some other important stuff... like getting the bearing caps on the correct way or torquing things to proper spec.
And I would bet that the cam and timing chain were installed "dot-to-dot". (not degreed)
I hope I'm wrong on all this... but leaving an oil pick-up tube out of a rebuilt engine is a big "red flag" in my book.
Users browsing this forum: DuckDuckGo [Bot], Google [Bot] and 29 guests
