It is currently Mon Feb 24, 2025 4:57 pm
 Post subject: 66 dart motor swap
PostPosted: Tue Oct 28, 2003 9:19 pm
can anyone tell me if I can use a mid 80s slant six in place of my original 66 without a lot of changes?,thanks in advance!!
 Post subject: Re: 66 dart motor swap
PostPosted: Tue Oct 28, 2003 10:14 pm
Yes, a later SL6 can be swapped into a 66
You will need to change oil pans and oil pick-up tube.
You will also need to add an adaptor ring to the back if the crank and use the later flex plate.
All the other needed parts from the 66 engine will swap over.
 Post subject: *1 Valve cover
PostPosted: Wed Oct 29, 2003 12:39 am
I need a valve cover from a 81 slant six head :twisted:
Mopar or Nocar But my wife drives GM
Users browsing this forum: Google [Bot], Semrush [Bot] and 75 guests
