It is currently Sun May 24, 2026 9:43 am
 Post subject: Nostalgia
PostPosted: Wed Jun 27, 2012 4:25 am
It would be interesting if we could get a few comments / stories / pictures from people who worked on the production line of Valiant cars in 60 to 62 (and yes I know they would be getting on in age).
Also I am interested in the numbering system for Valiant and other marques in the Chrysler / Plymouth / Dodge lines. for example part 8-31-10 also had the part number 2291 852, and when we look for parts with a supplier we quote the number 2291 852.
Were cars built on the production line in order of the part numbers, if not, what was the order, if any, when building the car on the production line?
I am currently restoring a 1962 Signet and it was originally painted white - 99% sure. When I removed the rear parcel shelf which I believe has never been removed before I discovered the rear internal panel where the 3 speaker holes are was painted beige. Any ideas why this is the case.
Thanks, Peter
 Post subject: Re: Nostalgia
PostPosted: Wed Jun 27, 2012 8:17 am
8-31-10 is not a part number. It is a parts catalogue category. These categories usually contain numerous part numbers for different models, body styles, colours, production dates, and vehicle configurations.
I'm not sure what this question means.
Perhaps the car wasn't originally white. What does the fender tag say?
PostPosted: Wed Jun 27, 2012 3:57 pm
The Signet was definately painted white as confirmed by code on tag. Interestingly the rear parcel shelf is a different color and I assume that on the production line it was perhaps taken from another car and built into the car I have now.
PostPosted: Wed Jun 27, 2012 5:52 pm
Painting was the last step after the body was already put together; a painted parcel shelf would not have been taken from another car (…?!) and installed in yours. Perhaps what you are seeing is primer or somesuch.
 Post subject: Yikes!
PostPosted: Wed Jun 27, 2012 7:09 pm
He's thinking that the part numbers are sequential to the assembly of the vehicle. Which it is not...nor is the sequence in the manual followed either...Section 8 maybe in the car before section 9...but they all wait until section 23 has been assembled first...
PostPosted: Wed Jun 27, 2012 10:26 pm
Yes, I was asking if the car was built in the order of the body numbering.
Does anyone know what sequence building a car took or was it random?
PostPosted: Wed Jun 27, 2012 11:45 pm
Er-ruh…random…?
Um…you don't really think the car factories were crazed mob scenes with workers falling over each other to throw random parts together and in the end, magically a car resulted…do you? Because no, that's not how it's ever been done.
Here, go read this.
PostPosted: Thu Jun 28, 2012 2:20 am
A great read; I would still like to know the sequence of building a car on the production line in the 60's - no computers, lots of cheap labour, no environmental issues, etc.
Thanks
PostPosted: Thu Jun 28, 2012 9:00 am
The process was pretty much the same as it is now, except no robots and dimmer lighting and more dangerous working conditions in the factory.
PostPosted: Fri Jun 29, 2012 8:03 pm
Car Model: 1964 Valiant
I once did a project in a GM heavy/medium truck plant. The pace of the work was not hurried. 5,000 employees worked on the 3 shifts. The equipment was probably about like it was in the '50s. At that time the management installed a robotic painting system because of EPA health regulations rather than efficiency. Four different types of truck cabs were built on the same production line, including the brown UPS trucks. Many of the trucks were custom ordered with unique equipment per fleet sales, some requirements were for unique paint schemes, fuel tanks, chrome and a hundred other variances.
PostPosted: Sat Jun 30, 2012 10:23 pm
Site Admin
I think the original question was more aimed at the steps taken in what order.
The big picture would be:
Base Chassis, undercarriage, electrical, power train, interior, Glass, Bolt on sheet metal, trim.
Or something like that. I don't know the exact relationship of the steps, so perhaps someone with more knowledge of the subject can chime in.
CJ
PostPosted: Sun Jul 01, 2012 11:32 am
Beige paint?White with a nicotine coating? :shock:
PostPosted: Sun Jul 01, 2012 11:42 am
I would bet that Dan has it right, primer of some sorts... They would only put the finish color in places that would be readily see-able, including places thats just overspray that you can see, but was not actually painted... IE: Underside of vehicle, wheel wells under hood etc...
MRO....
