It is currently Tue Oct 13, 2026 6:50 am
Post new topic  Reply to topic  [ 35 posts ]  Go to page Previous 1 2 3
PostPosted: Sun Aug 12, 2012 5:22 pm
Use a factory air cleaner with a thermostatic snorkel. An air cleaner with an open/exposed element is not better, it's worse.
+1. And rig up a true cold air intake while you are at it. No point in sucking in hot underhood air when it is so easy to rig up a cold air intake.
PostPosted: Sun Aug 12, 2012 7:00 pm
It's just temporary air cleaner for now to keep dirt out of the carb while I'm tuning and tinkering with it, I have a 10" that needs the bottom shaved down for my hood clearance.
Hmm...Cold air intake is a good ideal as well. Thanks for all the feedback.
74 Dart Swinger, supersixed.
PostPosted: Sun Aug 12, 2012 11:18 pm
Yes, a cold air take is really worth it in terms of mileage and performance. Take a look at mine.....cost is about $15 in a few common parts.
You can also view my simple aluminum heat shield which really works in two important ways. Keeping the carb cool and the number 1 runner warmer.
Click on the red link below my name to view pictures.
PostPosted: Mon Aug 13, 2012 12:18 pm
Hi Super6er.
There are some differences in the manifold to carb insulator gasket, between different BBD versions, be sure you have the correct one.
You will see them if you take a look in this manual, from page 26 -> on:
Carter BBD operation and repair manual(pdf)
Olaf.
Aspenized
PostPosted: Mon Aug 13, 2012 6:45 pm
Very good info thanks for sharing..
Users browsing this forum: Google [Bot] and 14 guests
