It is currently Tue Oct 13, 2026 10:48 am
PostPosted: Sat Mar 02, 2013 2:44 pm
I am trying to finish the intake and exhaust manifold on my truck and I can't remember how the linkages go on the carb. also I can't seem to remember where the springs go. PLEASE HELP! I need to get the truck back on the road. Thanks
PostPosted: Sat Mar 02, 2013 3:46 pm
It would be a big help if we knew what year and make /model carb you're installing. Linkages, springs and vacuum hoses change with those factors. Help us help you.
ATB
BC
'64 Dart GT convertible, 64 Dart 170 2-door post sedan in faded blue and rust (the Az Dart) & a sixty THREE Dart 170 2-door post sedan in faded blue and rust. (future project)
Early Dart Disorder (EDD) is real, and I've got it!
PostPosted: Sat Mar 02, 2013 4:15 pm
thought about that after i went back outside. My truck is an 86 and i have a holley 1945 carb. I have the vacuum lines figured out just need the linkages and springs thank you
PostPosted: Sat Mar 02, 2013 4:18 pm
You can look at my photos......just click on the red link below my name.
My car came with a 1945 but replaced it with a 1920 Economaster. It shows the cable linkage and springs..... :)
PostPosted: Sun Mar 03, 2013 2:38 pm
thanks! your pictures help me a little but it may be better if someone that has the same setup as me could help. I have 3 springs and am only seeing 2 on your setup.
PostPosted: Sun Mar 03, 2013 5:51 pm
Two springs are the throttle return springs, one spring is the kickdown linkage tensioning spring. The two springs have a large coil and a small coil. The small coil nests inside the large coil. This "spring pack" runs between the throttle arm on the carb and a little bracket that bolts to the choke thermostat pocket on the exhaust manifold. The third spring hooks to the kickdown arm and to the throttle arm on the carb.
