It is currently Sun Jan 12, 2025 7:45 am
 Post subject: Custom intakes
PostPosted: Mon Mar 11, 2013 4:22 pm
Car Model: Custom Kart build
Anybody build a custom slant intake? Particularly 2bbls but anything is welcome! Lets see em!!
PostPosted: Mon Mar 11, 2013 4:34 pm
6 Pack Dart
You asked you get! :lol:
Richard
PostPosted: Mon Mar 11, 2013 4:37 pm
Nice set up!
PostPosted: Mon Mar 11, 2013 5:23 pm
We made some Hyper-Paks manifolds, back in the mid 1990's.
PostPosted: Mon Mar 11, 2013 5:29 pm
Richard
are they motorcycle cv carbs?
PostPosted: Mon Mar 11, 2013 5:54 pm
6 Pack Dart
Yes Mikuni from Suzuki 4 cyl.
Richard
PostPosted: Mon Mar 11, 2013 5:55 pm
Here's a 1 barrel I modified for a 2 barrel. Don't know why the pics are so dang big. Click on "Super Six Conversion Stromberg" under my signature for more.
<a href="http://beta.photobucket.com/" target="_blank"><img src="http://i1082.photobucket.com/albums/j376/TowlesToad/Super%20Six%20Conversion/DSC00613.jpg" border="0" alt="OEM EGR and block off plate photo DSC00613.jpg"/></a>
<a href="http://beta.photobucket.com/" target="_blank"><img src="http://i1082.photobucket.com/albums/j376/TowlesToad/Super%20Six%20Conversion/DSC00614.jpg" border="0" alt="1 barrel cast manifold milled down with 2 barrel plate MIG welded on. EGR blockoff added photo DSC00614.jpg"/></a>
<a href="http://beta.photobucket.com/" target="_blank"><img src="http://i1082.photobucket.com/albums/j376/TowlesToad/Super%20Six%20Conversion/DSC00625.jpg" border="0" alt="Modified manifold cleaned and painted photo DSC00625.jpg"/></a>
<a href="http://beta.photobucket.com/" target="_blank"><img src="http://i1082.photobucket.com/albums/j376/TowlesToad/Super%20Six%20Conversion/DSC01195.jpg" border="0" alt="Manifold mounted, Looks good. Nice fit to the head photo DSC01195.jpg"/></a>
<a href="http://beta.photobucket.com/" target="_blank"><img src="http://i1082.photobucket.com/albums/j376/TowlesToad/Super%20Six%20Conversion/DSC01196.jpg" border="0" alt="Choke thermostat mounted photo DSC01196.jpg"/></a>
PostPosted: Mon Mar 11, 2013 6:11 pm
61 V200, that's what I want! I'm tryin to buy a aluminum super six manifold at the moment but if I can't get that one I wanna modify a 1bbl like that! You wouldn't happen to have plans/drawings/instruction or a build thread for it would you?
PostPosted: Mon Mar 11, 2013 7:14 pm
No plans, no drawings just a "seat of the pants" approach. Somewhere there is an article about how to modify a barrel using screws and epoxy. Check the articles section or maybe someone will post a link.
I took a little different approach.
First thing was to make an adapter plate. I just took a 2 barrel gasket and some 1/2" plate and went at it. Then I clamped up a 1 barrel intake on the mill and used a fly cutter to take the one barrel mount down flush with the top of the intake plenum. I used a Heli Arc to burn the plate to the cast intake with no problem and that was it.
Notice the adapter allows for the carb to sit parallel with the intake runners as opposed to a stock 2 barrel which runs perpendicular. The jury is still out on whether or not this promotes better distribution of the fuel through the runners. I went that route because I have a solid throttle linkage set-up. You can see that in the link under my signature.
Just a few things to keep in mind.
1. You will notice the mounting surface for the carb does not sit level with the runners. This is because the intake does not sit level in the car so the angle compensates to keep the carb level. This is important to know when you clamp the intake to the mill. (I've heard of guys actually and successfully using a grinder to knock the 1 barrel mount off. Might want to have a few extra intakes to practice on. They are cheap and easy to find.)
2. Keep a handle on the finished height of your setup which will be determined by the thickness of your 2 barrel adapter, what type of carb you are using and also your air cleaner set-up. I got lucky with the 1/2 inch plate, Stromberg ww-275 and a Super Six air cleaner. Sure would suck to have to cut a hole in the hood to let the air cleaner stick out :lol:
Good luck! And keep us informed on your progress.
PostPosted: Mon Mar 11, 2013 7:26 pm
Eventually I'd wanna run a holley 2300 set up for blow through and just bout 8-10psi boost.
PostPosted: Mon Mar 11, 2013 8:10 pm
Richard
did you make the intake? from steel?
1980 Aspen 4 speed
PostPosted: Mon Mar 11, 2013 8:33 pm
I made a plate to mount a Holley 2300 series carb on a modified 1bbl manifold.
PostPosted: Mon Mar 11, 2013 9:03 pm
Thanks guys!
PostPosted: Mon Mar 11, 2013 9:25 pm
6 Pack Dart
Richard
Flanges from Washington state (E-Bay seller) mandrel bent exhaust tubing 1 peice, few feet of straight exhaust tube, all steel, cut and fitted, gas welded.
Richard
