It is currently Sat Nov 28, 2026 11:19 am
 Post subject: Cluster volatage limiter
PostPosted: Mon Apr 22, 2013 10:07 pm
I've found lots of talk about the instrument cluster voltage limiter, but no mention of if or where replacements are available. Car in question is a '76 Dart (I wouldn't mind converting over to the '72-'75 cluster if that would make a difference in the availability of the limiter). I have good fuel and temp gages to install, and want to replace the limiter while I'm at it so I start off on the right foot. Thanks in advance for any direction.
PostPosted: Mon Apr 22, 2013 10:37 pm
Do a search. Dan linked to an aftermarket supplier of new transistorized voltage regulators and there is also and article on Allpar about how to use Radio Shack parts to build your own transistorized voltage limiter.
Sorry, I don't have the links handy.
PostPosted: Mon Apr 22, 2013 10:47 pm
Do a search.
I tried earlier today and came up empty, but I'll keep trying different keywords. Thanks for the tip Reed! Neil mentioned knowing somewhere once, but I haven't seen him on here in a bit.
PostPosted: Tue Apr 23, 2013 6:41 am
try here for homemade voltage limiter or here for one already assembled.
PostPosted: Tue Apr 23, 2013 7:05 am
RTE makes a nice one, so I hear.
I used the 7805 voltage limiter conversion , which works OK.
 Post subject: Limiter the same
PostPosted: Tue Apr 23, 2013 7:33 am
Limiter should be the same 1967-1976, the only difference in 1976 is you have more pins and extra traces for the shunt ammeter (up to 1975 the ammeter is not on the circuit board and has two threaded terminals for direct power from the power circuit.
PostPosted: Tue Apr 23, 2013 10:15 am
Wow, thanks for the links, guys! That RTE piece sure looks nice, but I'm also a cheapskate, so I might try the Allpar trick. I just noticed the credits at the top of that article, Ehrenberg sure thinks highly of himself... :roll:
Okay, thanks D.I. I knew the ammeter was different, but wasn't sure what else changed. Call me crazy, but I prefer the direct ammeter in the <'75s.
PostPosted: Thu May 09, 2013 9:41 am
Car Model: 75valiant custom
i love ehrenberg! i think he's the most entertaining automotive writer out there. it's all just part of his style.
PostPosted: Mon May 13, 2013 6:44 pm
because my fuel gauge, temp gauge, and oil light were all not working, and the speedo had a little bit of bounce, i decided to bite the bullet and pull the cluster. the good news is, much of my stuff is in pretty good shape. the bad news is, virtually every dash light bulb has broken ears on the base.
where can you get new ones?
PostPosted: Fri Nov 29, 2013 9:48 pm
google search for: "mopar dash light socket". More choices than you can shake a stick at.
BC
'64 Dart GT convertible, 64 Dart 170 2-door post sedan in faded blue and rust (the Az Dart) & a sixty THREE Dart 170 2-door post sedan in faded blue and rust. (future project)
Early Dart Disorder (EDD) is real, and I've got it!
Users browsing this forum: Amazon [Bot] and 4 guests
