It is currently Fri Jan 02, 2026 12:13 pm
 Post subject: Rocker arm jam nuts
PostPosted: Sat Apr 27, 2013 8:03 am
I need to know what size half nut ya'll are using for your rocker arm adjusters.I have 3/8-24 but they seem way too tight.all help is welcome as I am tired of readjusting my valves every time I run over 5000 rpm.Thanks in advance. HyperValiant
1960 Hyper-Pac Valiant(rolling test-bed)
1963 Valiant V2OO(Son's summer project,- he just turned 15 :-) )
1972 Valiant 4dr(Daughter Kelly's repair in progress)
1974 Valiant (v8) daughter Kelly's work in progress
PostPosted: Sat Apr 27, 2013 8:36 am
I use 3/8NF half nuts....
 Post subject: half nuts
PostPosted: Sat Apr 27, 2013 12:02 pm
I believe they are 40 threads to the inch.
'72 Duster (Performance 360)
'83 Ramcharger (Performance 318)
'80 TrailDuster (360)
'80 D-150 Truck (See Below)
CompCams 252S, Holley 390cfm, Offy manifold
Ported, Polished and Gasket Matched
P4286813 Springs,0.040 Overbore,
0.090 Shaved Head
PostPosted: Sat Apr 27, 2013 12:16 pm
3/8 UNF = 24 threads per inch
PostPosted: Mon Apr 29, 2013 3:21 am
Yes, 3/8 - 24. They will be tight because the rocker screws are made to be tight. You can run a die over them if you really want them looser.
PostPosted: Mon Apr 29, 2013 10:22 am
Thanks fellas,now maybe I can keep a good lash on this engine.
I know that I should probably get shorter push rods but this is the last season for this engine and probably the last 170 Ill build for a while.
Thanks again
HyperValiant
Users browsing this forum: Google [Bot], Rick Covalt and 15 guests
