It is currently Sun Jan 26, 2025 9:45 pm
PostPosted: Wed May 22, 2013 2:04 pm
Lean burn computer is gone, waiting for the carb to come back from the rebuild shop. Does anyone know if I need to do anything to the engine bay harness? ( 83 B150 van ) Can I just leave the computer connecters in place ? Or do I need delete or reroute any of the wiring? :roll: Any help would be great.
83 B150 /6 4spd
97 JeepWrangler Sport 4.0
2001 VW Beetle TDI 5sp
2000 Nissan Xterra
73 Dodge B300 van
 Post subject: Oops
PostPosted: Wed May 22, 2013 2:05 pm
This is a lean burn to GM HEI super six conversion
83 B150 /6 4spd
2000 Nissan Xterra
73 Dodge B300 van
PostPosted: Wed May 22, 2013 2:35 pm
You can leave all the lean burn wiring in place and just replace the distributor. Use the coil (+) feed wire as the trigger for the relay that feeds the HEI unit. Otherwise the wiring for the HEI is completely independent from any of the other wiring.
PostPosted: Wed May 22, 2013 3:10 pm
Thanks Reed, I wasnt sure if everything would work with the computer removed. 74 dizzy is rebuilt and in place, carter BBD is being rebuilt, should be done by the weekend I hope-
83 B150 /6 4spd
2000 Nissan Xterra
73 Dodge B300 van
PostPosted: Wed May 22, 2013 3:19 pm
Good luck! You certainly can remove all the lean burn wiring if you want to. It really cleans up the engine bay, but you don't HAVE to do it. If you can, I recommend going ahead and replacing the stock coil with a Ford e-core coil to get the most out of the HEI conversion. A stock late 80s or early 90s Ford Mustang or truck coil is fine and shouldn't cost too much at the boneyard.
PostPosted: Wed May 22, 2013 5:17 pm
Thanks again Reed, I'll post my results when I get her running
83 B150 /6 4spd
2000 Nissan Xterra
73 Dodge B300 van
Users browsing this forum: Ahrefs [Bot], banzaibullitt and 3 guests
