It is currently Sat Jun 13, 2026 12:30 pm
Post new topic  Reply to topic  [ 73 posts ]  Go to page Previous 1 2 3 4 5 Next
PostPosted: Thu Jul 18, 2013 7:54 am
I received the specs on the cam from Mr. Grundy:
"I found a sheet that summarized the components in the engine. I will attach it.
The camshaft that I designed had the following:
* intake opening 32 deg before TDC
* intake closing 84 deg after BDC
for a total duration of 296 deg
* exhaust opening 80 deg before BDC
* exhaust closing 36 deg after TDC
* valve lift of .440"
PostPosted: Thu Jul 18, 2013 10:19 am
That add hangs in my toolbox. I cant believe it surfaced after all these years.
Thanks for posting.
Will
PostPosted: Thu Jul 18, 2013 1:13 pm
Wow! What an amazing piece! I hope it stays in Michigan...maybe I'll be able to check it out in person some day. Perhaps right there at the Gilmore if they are lucky enough to get it.
DynoDave
1970 Plymouth Duster
1972 Dodge Charger Rallye
1977 Chrysler Cordoba
WPC # 12304
PostPosted: Thu Jul 18, 2013 4:00 pm
Was there any oiling to the cam and followers? :?:
PostPosted: Fri Jul 19, 2013 8:14 am
I'm impressed to see this and reference using it to gain momentum on doing OHC hemi. I'll dig through but I'm pretty sure there is a picture of an old hemi that was set up OHC too but never took off. Two one of a kind OHC engines, and the slant is the one found Sweet!
Pohlman
Edit: found in Aug 2013 car craft. It was chryslers A-925 dual overhead cam engine R&D. So not exactly what my memory had thought.
225, Offenhauser, Holley 350, A833OD, 3:55, GM HEI,99 Durango starter
BOOSTED! WH1C, BIG FMIC, 10#
Operation Noble Eagle 03-05
Operation Iraqi Freedom 05-07
Operation Enduring Freedom 12- 13
PostPosted: Fri Jul 19, 2013 11:24 am
I am wondering why you would want to do an OHC thing with a 392 when it was long obsolete by then?
Even the Gen 2 Hemi was phased out by '71.
PostPosted: Fri Jul 19, 2013 12:01 pm
Ask and ye shall receive! I got more pictures and answers from Mr. Grundy in this morning's e-mail. I find this all very fascinating. it is fun to see what you can do with a little ingenuity.
Mr. Grundy's e-mail:
Here are answers to some of the questions.
Here is a pic of the drive pulley attached to the crankshaft.
Oil is supplied from the rear cam bracket. Here is the oil hole in the head at the rear cam bracket location.
This is the rear cam bracket with oil supply to the rocker arm shaft.
This shows an oil supply hole in a cam bracket that provides oil to the Torrington cam bearing in the bracket.
The rocker arms obtain oil from the small holes and the cam bearings obtain oil from the large holes. Three of the large holes have inserts to enable locking pins to engage to properly locate the rocker shaft in the cam brackets.
This shows the oil supply hole in each rocker arm.
This shows the oil supply hole at the top of the valve lash adjuster.
My musings- correct me if I am wrong, but it looks like the factory style valvetrain oiling was retained with the factory rocker arm shaft being used.
PostPosted: Fri Jul 19, 2013 12:03 pm
and if prototyping this particular set up for potential use on a V engine,, it would be more applicable to a wedge head that had the valves in line,,, as opposed to the hemi valves that are spaced apart and angled....
but with time and money,, anything is possible. :!:
PostPosted: Sat Jul 20, 2013 5:12 am
Speaking of money, what is the asking price for the engine?
PostPosted: Sat Jul 20, 2013 5:53 am
Poser
Probably......
http://www.youtube.com/watch?v=l91ISfcuzDw
PostPosted: Sat Jul 20, 2013 1:19 pm
Speaking of money,,,, the owner and I exchanged a few pm's, he said he will put it on e bay which due to the uniqueness of the parts is the right thing to do. Just a factory original hyper PAC intake and exhaust manifold set will have a value comparable to a dream vacation in the Bahamas. If the lifters are actually ford sohc 427 parts, bet there is someone looking for those. The complete ohc setup could have value just due to the wow factor. I say,,,let it rock!
PostPosted: Sat Jul 20, 2013 4:26 pm
A big THANK YOU to Reed for his effort in hosting these pictures, and in conveying questions and answers related to this engine.
Olaf
Aspenized
PostPosted: Sat Jul 20, 2013 5:42 pm
The problem is the very limited appeal of this motor. While I and other hard-core slant junkies drool over this, honestly, how many hard-core slant six junkies are there? The OHC was never a factory option, so Mopar parts and ephemera collectors won't be interested. The hyperpak stuff will bring some interest, but I think the rest of the motor has a very small pool of interested buyers. Of course, maybe the person that bought the XNR will crawl out of the woodwork and buy this equally rare piece of slant six history.
PostPosted: Sat Jul 20, 2013 8:08 pm
Car Model: '23 T-bucket
We need a slant six museum.........
Roger
PostPosted: Sat Jul 20, 2013 10:13 pm
Jimgrundy, I guess our collective awe made us forget: Welcome to the forum!
I doubt if any first posts ever have blown so many people off their chairs as your did!
Absolutely awsome material!
Olaf
I second this!
Wil
66_Fury
Old man Sherman wishes for 1 more Barrel.
A wolf that lies in his lair never gets meat, or
A sleeping man victory.
