It is currently Sat Nov 21, 2026 10:55 pm
 Post subject: cold lash
PostPosted: Sun Aug 11, 2013 9:18 am
I'm ready to install my engine, but I want to check valve lash cold, just to make sure they have it ballparked before I start it up and adjust hot.
What is the procedure to check/set the lash cold?
Thanks everyone,
BG
 Post subject: let me clarify...
PostPosted: Sun Aug 11, 2013 7:38 pm
I know the procedure, but what is the appropriate setting for valve lash cold? I only need it to run for break in, then I can set hot. I just want to make sure they're not too tight or loose during break in.
What do people typically do for a rebuild, set the gap at a thousandth or so looser than spec to account for expansion?
thanks,
BG
PostPosted: Sun Aug 11, 2013 7:41 pm
Sure
PostPosted: Sun Aug 11, 2013 8:34 pm
Actually, if you figure it, the lash will get tighter as it heats up. I'd set the lash 2thousandths looser to start.
70 Plymouth Valiant 4dr
PostPosted: Mon Aug 12, 2013 7:28 am
Lash on a first start is always done cold first. When it is warm for the first time you can do a torque n lash . After a first move (drive the car) I would lash again.....and check for leaks.
That first lash can be any clearance that makes it run well at cam breakin rpm. Looser will tame a wildo cam down a bit.
On a street motor I would cold lash to spec.....breakin the cam (we are not getting real hot) and relash.
I prefer to do static lash while warm.......you may have another method.
 Post subject: Thanks...
PostPosted: Mon Aug 12, 2013 9:54 am
I'll set a few thousands loose, do the break in, then set lash hot to spec.
BG
