It is currently Mon Apr 27, 2026 8:11 pm
Post new topic  Reply to topic  [ 34 posts ]  Go to page Previous 1 2 3 Next
 Post subject: question?
PostPosted: Thu Aug 29, 2013 1:52 pm
I just bought the HVH quick fuel 1&2 inch phoenlic spacer for the 4150 square bore carb.
Rick, I know they cost a bit, but it's cheaper than lighter wheels or redoing the engine or trans now.
if I can pick up .2 seconds for $127 then I feel it's worth it.
Here's my question does the contoured section of the four holes point up toward the bottom of the carb or down toward the engine?
no manuals or instructions came with the spacers.
Thanks! Greg
PostPosted: Thu Aug 29, 2013 2:28 pm
For sure! :lol:
Can someone explain what the carb spacer is doing? I understand there is more volume under the carb but how does it make more horsepower? Is it allowing a more gradual turn and thus more flow or just what is it doing? Help my pee brain!! :lol: :lol:
Rick
PostPosted: Thu Aug 29, 2013 4:26 pm
Greg 1'' may not be enough for a stout engine,So a 2''or more may show some gain.Or maybe your combination is "just right" the way it is,,,And don't need any more "ram" effect. :cry: But as they say"You'll never know if you don't try".
PostPosted: Thu Aug 29, 2013 4:28 pm
OOP"S Rick. Forgot to say,,Just think of it as a poor man's tunnel ram and you'll get the idea. :wink:
PostPosted: Thu Aug 29, 2013 4:33 pm
Got it, thanks!
PostPosted: Thu Aug 29, 2013 6:20 pm
Okay, CNC dude, So which side up towards the base of the carb Smooth radius side or the 90* edge side?
If you leave me hangin' I might just have to try it both ways and see if ones better...
PostPosted: Thu Aug 29, 2013 7:26 pm
Car Model: 64 Valiant
I radius mine on both sides. You wouldn't believe me if I told you how much CFM gain there is in doing it.
PostPosted: Thu Aug 29, 2013 7:43 pm
Do you have a picture?
PostPosted: Thu Aug 29, 2013 7:54 pm
You don't want a step in the direction of the airflow.
If you do have a small step, smaller to larger is OK.
Avoid larger to smaller steps.
PostPosted: Thu Aug 29, 2013 8:27 pm
I'll post one when I get home tonight(this morning).
Here you go....
PostPosted: Fri Aug 30, 2013 4:08 am
Thanks for the post, I guess i will have to post some pics to accompany my question.. I didnt quite get the answer I was looking for,.
I will post again when I can get some shots of the spacers I ordered.
PostPosted: Fri Aug 30, 2013 9:20 am
What was your question more specifically.
PostPosted: Fri Aug 30, 2013 2:03 pm
Which End Up?
Which one of these faces the throttle blades under the Carb?
This end?
or this one? With the Radius work?
Many Thanks!
PostPosted: Fri Aug 30, 2013 3:47 pm
Oh ok, I think the HVH style are designed for the cavity portion to point downward and the 90° sharp edge of the throttle bore to fit against the carb base.
PostPosted: Fri Aug 30, 2013 6:27 pm
What's the opening on the manifold look like?
