It is currently Mon Nov 23, 2026 3:33 pm
 Post subject: help with flywheel
PostPosted: Wed Feb 26, 2014 2:13 pm
I'm switching over from 170 three on the on a 64 dart to a 1968 225 dart engine can anybody tell me will my flywheel interchange or what do I need. ? Have not pulled the 170 yet thanks.
1964 Savoy post 426 Wedge 4 speed
1972 Challenger Rally 340
1973 Challenger Rally 440
AND SOME GM Stuff
DART 170 Manual
PostPosted: Wed Feb 26, 2014 2:28 pm
No you need a 68 and up flywheel but you may want to wait until you pull the motor maybe the engine has been replaced before and it may have a newer engine. Also the exhaust pipe may need a 1 inch spacer at the manifold the 225 is 1 inch taller block
Brian
63 Plymouth Valiant Wagon
 Post subject: Or...
PostPosted: Wed Feb 26, 2014 4:51 pm
for the 1968 engine you need a 1968-1987 flywheel...or if the 225 is going to the machine shop you can pull your current pre-68 flywheel and have the shop hone the center out to the larger crank register...
Which ever is easier and most economical for you.
-D.idiot
Users browsing this forum: Bing [Bot] and 6 guests
