It is currently Fri May 22, 2026 11:16 pm
PostPosted: Fri Mar 21, 2014 9:30 am
Car Model: 87 B150, 1970 Valiant 4-door
I know you are not supposed to reuse them, and I never have before, but...
I just broke a leaf on my van. I secured a matching pair of '95 B-1500 springs and new u-bolts from Rockauto.com.
I don't think I will have weather or dailight to clean and paint everything.
If I install this stuff now, can I reuse the u-bolts when it's warmer, and I have a chance to paint everything, or are they ruined once they are torqued the first time?
PostPosted: Fri Mar 21, 2014 10:35 am
the only reason for not reusing leaf spring u bolts would be due to rust and corrosion. Put some anti sieze on the threads and they will come apart with less hassel
PostPosted: Fri Mar 21, 2014 12:02 pm
Cool. thanks.
(thought I read something about streching/twisting, or something by virtue of simply installing them.)
I've always had to cut them off because of rust, so I never knew about if they weren't rusted.
PostPosted: Fri Mar 21, 2014 2:03 pm
I've never heard that before, a torque-to-yield u-bolt? Doesn't sound safe to me.
I've always reused u-bolts, haven't broken one yet, but that's just my 2 cents.
PostPosted: Fri Mar 21, 2014 2:13 pm
at $50 for a set, I'd replace them. Cheap Insurance on an Old Car.
Do They SALT the roads in NJ? :shock:
1964 Dart GT
PostPosted: Fri Mar 21, 2014 3:42 pm
Hell yes! During all the snow/ice/freezing rain storms we've had this past winter the DOT put down enough salt to turn every car & truck that "crusty-white" color. You could HEAR the metal rusting away.
@ Ed
If you want to put antiseize on the U-bolt threads, you need to reduce the torque some (don't know by how much)- because antiseize is a high pressure lubricant. I'd also put jam nuts on 'em - then recheck torque in a few hundred miles. Sometimes things can "settle" with use, & you DON'T want to lose a U-bolt.
63 Valiant Wagon
225 - 4 bbl
PostPosted: Fri Mar 21, 2014 8:33 pm
$50 a set??? Where, from YearOne? Try $3 from ESPO each.
Just watch the threads, they tend to get munged. Before unthreading, wire brush or clean the threads as best you can.
PostPosted: Fri Mar 21, 2014 11:19 pm
Don't use an impact. It will heat the nuts up and gall the threads.
PostPosted: Fri Mar 21, 2014 11:31 pm
+1
PostPosted: Sat Mar 22, 2014 5:49 am
Are you going to replace them now and asking if you can reuse these later when you pull them to paint?
Dave
86 Miser 170,000+
2 1/4" exhaust
Holley 1920 #55
HEI MSD BLaster 2
17.8 mpg
PostPosted: Sat Mar 22, 2014 6:23 am
http://www.firmfeel.com/Uboltkit_a.htm
1964 Dart GT
PostPosted: Tue Mar 25, 2014 11:29 am
Exactly.
I took them off this past weekend.
One actually came off without breaking (threw it out anyway).
Thanks for all the replies.
PostPosted: Tue Mar 25, 2014 2:32 pm
Firm Feel is great, but if you can find the same product elsewhere, it will be cheaper. U-bolts are 1/4 the price at ESPO, torsion bars are 1/2 price at Just Suspension, but things like seamless tube tie rods aren't available anywhere else. So I use Firm Feel when I need to, but shop around first.
Ed, I've heard many people caution against reusing u-bolts as well, but have yet to have a u-bolt failure myself (broken leaf spring centering pins and stressed u-bolts pretty badly, though). Funny I never hear the same logic applied to head bolts, or lug studs, or anything else for that matter?
PostPosted: Tue Mar 25, 2014 2:45 pm
I rarely reuse axle u-bolts for two reasons: (1) I usually can't get the nuts off without the nuts seizing and me having to cut the bolts off anyway, and (2) I can get a set of four brand new u-bolts bentup for about $20 at the local springs shop. Why chance it when it is so cheap to just buy new?
Head bolts don't have the same corrosion issues as rear axle u-bolts, lug studs are nearly always protected rom rust by the lug nut or hubcap.
PostPosted: Tue Mar 25, 2014 3:06 pm
If I am not mistaken, don't factory U bolts have the inside of the U-bolt flatter so that they have a larger surface area when you clamp them down? Seems like I remember that from somewhere.
I have always re-used U bolts with no problem. I wire wheel the old ones and spray with Kroil before I start the removal process. :lol:
