It is currently Fri Jul 10, 2026 8:52 am
 Post subject: Nitrous on my /6
PostPosted: Sat Jan 24, 2004 11:29 am
My friend has been helping me set this up for my 66 barracuda. I hope to eventually run 250-300HP of nitrous on my 225. I'm only in the begginning of working on a motor, and was wondering what certain products would be good for this kind of power. My goal is 200/motor HP and 300/nitrous. Thanks.
PostPosted: Sun Jan 25, 2004 1:00 am
Wow, that looks nice, great plumbing work.
Looks like that system will flow some serious juice, way more then my "swapmeet special" set-up I did.
http://www.dutra.org/pictures/engine/du ... sclose.jpg
On a side note, be sure to do a fit check with that Clifford H-Pak manifold,
side clearance to the header pipes and around the nuts is a problem. (some grinding is required)
See DI's thread on his H-Pak install for more info. (search for hpak)
http://www.slantsix.org/forum/viewtopic ... light=hpak
PostPosted: Sun Jan 25, 2004 5:23 am
Are you building a race only car, or a street terror?
PostPosted: Mon Jan 26, 2004 3:51 pm
It is my daily driver. :twisted:
Doctor Dodge- I met you at the slant six meet in Milpitas. I was driving the black 66 barracuda, and Rob Moore was with me. He did all the bending on the nitrous. It started as the sportsman kit for a V8. Hopefully we can go to the track together when it opens up again.
PostPosted: Mon Jan 26, 2004 7:13 pm
Wow, get that sucker together and lets "do" Las Vegas in March!
http://www.slantsix.org/forum/viewtopic.php?t=6455
Users browsing this forum: Amazon [Bot] and 1 guest
