It is currently Mon Jun 15, 2026 11:07 am
 Post subject: Oversized head gasket
PostPosted: Tue Jun 10, 2014 3:08 am
Is anyone here aware of these being avail. I was told on another forum that oversized bores were avail for the slant
PostPosted: Tue Jun 10, 2014 3:17 am
Yes the Permaseal Head Gasket from Australia is a 3.66 bore head gasket.
Rick
PostPosted: Wed Jun 11, 2014 3:19 am
Rick
Thanks, yes evidently there is no oversized gasket avail here in the states. I have called around
 Post subject: Why?
PostPosted: Wed Jun 11, 2014 5:25 am
The felpro and Victor Reinz are 3.5 bore size...considering that the stock slant is a 3.4" bore that will get you through all the overbores a street motor needs (20,30,40,60,80...and the long rods at .45), the only reason to go past that is for maximum performance...with an over bore past .100 you have to pick and check your blocks and other prep has to occur that may not be so street friendly.
Any reason you'd need that kind of over bore in a truck?
PostPosted: Wed Jun 11, 2014 1:08 pm
Yes, I ordered the last group buy on the gaskets that came from Australia. I think I ordered 20 of them and the shipping alone was over $200. Not sure what the shipping would be on one or two gaskets.
Rick
PostPosted: Wed Jun 11, 2014 1:32 pm
How big do you need? ACL was making a gasket that was 3.54" or so. Aussie Permaseal (now called Endurotec) is the 3.66" one.
 Post subject: Re: Why?
PostPosted: Wed Jun 11, 2014 2:45 pm
No I am good with the only reason I was asking is cause it was mentioned to me on another forum that I should get an oversized gasket.
I think the poster was confused a bit but its all good.
PostPosted: Wed Jun 11, 2014 2:46 pm
Thanks for the tip but the stock bore size will be just fine.
