It is currently Tue Jun 02, 2026 1:37 am
 Post subject: engine weight
PostPosted: Thu Jul 03, 2014 7:04 pm
Car Model: 1966 Plymouth Valiant
any one know the weight of a bare block 225? cast iron. Early block 3 freezeout plugs.
PostPosted: Fri Jul 04, 2014 5:20 am
What year? It makes a big difference.
Here's what I have weighed (with caps, but nothing else):
'64-66 Blocks = 162-166 lbs
'68-72 blocks = 165-169 lbs
'84-up cast crank = 140-145 lbs
PostPosted: Fri Jul 04, 2014 6:15 am
Lou, What about the blocks between 72 and 84? Do you have data on those? My "new" block was cast in september of 82. The head is dated '83, so assume the engine was in a 83 truck of some description. Is it likely to be the lighter variety? Do you have data on the crank weights? Thanks.
Sam
PostPosted: Fri Jul 04, 2014 7:27 am
If I knew more about blocks, I would have posted it.
Cranks:
'64 - 72 = 76 lbs (plus or minus 1lb or so)
'75 = 74-76 lbs (early cast crank)
'84 - 85 = 60 lbs
I have no data on 82-83 motors. Some say they are light cranks, but I don't know the year cutoff. Best to weigh everything you have.
PostPosted: Fri Jul 04, 2014 7:44 am
OK, Thanks. I was hoping you had a typo in there and meant "before" 84. I make that kind of mistake all the time. Oh well. I can measure mine when it is torn down.
Sam.
 Post subject: block weights
PostPosted: Fri Jul 04, 2014 8:28 am
Thank you!!!
PostPosted: Fri Jul 04, 2014 12:41 pm
Thanks, Sam. I'll be interested to see what you have in that 82-83 motor.
