It is currently Fri Feb 28, 2025 2:32 am
 Post subject: Blown Oil Pan Gasket
PostPosted: Fri Aug 22, 2014 3:20 pm
I hope this isn't a really common questions here, I couldn't find any threads that answered my question. I noticed my car leaking oil pretty bad about a month ago so I put it up and inspecting it to find that the front of the oil pan gasket is really worn out, looks like in some areas it's even completely missing. The bolts were loose.
I tightened them up, cleaned the area and applied RTV in every location I could get to. It really slowed the leak down for a week but it's back at pouring oil all over my street.
So I'm wondering how difficult it would be to replace the gasket properly with out having to pull the motor. My 78 Aspen 4 door has a honkin' K member right under the oil pan and I doubt I could remove the pan with out moving the motor at least a bit. A coworker recommended using a 2x4 and a floor jack to lift the motor a bit to get some extra clearance. Not sure how that would work though.
What do you guys think? Is this possible?
1978 4 door Dodge Aspen, Super Six
PostPosted: Sun Aug 24, 2014 10:33 pm
I have been under that car, its a bit crowded. You're gonna have to lift the motor high enough to put wood blocks under the motor mounts. Or you could remove the driveshaft and disconnect the trans and push it back.
70 Plymouth Valiant 4dr
PostPosted: Sun Aug 31, 2014 10:04 am
I just did this on my 340 car. I had to unbolt the motor mounts, lift with block of wood under the oil pan, and then place wedges between the motor mounts and the k-frame. I also had to disconnect the steering, so I replaced the steering components at the same time: swapped for the bigger tie rods- a direct fit item, new pitman and idler arms.
/6 '67 Barracuda convertible, electronic ignition, 4-OD, street cam, SBP KH discs, 3.55 SG 7.25" 1" t-bars. Bilstein.
340 '67 fastback, Doug Nash 5-speed.
1988 Toyota pickup work truck
Users browsing this forum: Bing [Bot] and 14 guests
