It is currently Tue Feb 25, 2025 12:45 pm
PostPosted: Thu Nov 20, 2014 11:09 am
Hello, head is dropped off at machine shop. What is the stock head thickness from the head mating surface to the valve cover on a drool tube head? I need to know if it has been machined before - I want to have .065 milled off. . .Thanks!
Tom
'86 Alfa Romeo Spider, red "Dinsdale"
'10 Corvette, red "" (no name yet)
'95 Ferrari 348, red "Zoom"
'04 Maserati, black "Evil"
'05 Aston Martin DB9, green "Bond, Treasury bond."
'82 Dodge W150 Power Ram, yellow "E. Valdez"
PostPosted: Thu Nov 20, 2014 12:54 pm
Found it here after a bit. 3.595 to 3.606
Tom
 Post subject: If...
PostPosted: Thu Nov 20, 2014 4:09 pm
If you installed O/S valves or did chamber work, you will have to CC the head, as that work has a tendency to change the volume compared to just using a stock head with no valve work...If you are having this kind of work done, head thickness won't matter, CC the head, apply the .0066=1cc rule to the cut and adjust the cut per your SCR calculation.
Good Luck,
 Post subject: Re: If...
PostPosted: Thu Nov 20, 2014 6:47 pm
Good Luck,
Ok, will do. Yes, OS intake and yes a tiny bit of chamber work. Wanted to make sure the head hadn't been cut before. I'll get a chamber volume after they put in the new valves.
Tom
Users browsing this forum: No registered users and 37 guests
