It is currently Wed Feb 26, 2025 12:29 pm
 Post subject: Bronze Lined Bearings?
PostPosted: Tue Nov 25, 2014 6:36 pm
Been working engines for a few decades and never ran across this: Mopar bronze surfaced rod bearings...... What purpose are these for, and what do they do that is special or different ?
PostPosted: Wed Nov 26, 2014 5:24 am
Never heard of them, either. Can you show a link or something? Where did you hear about them.
 Post subject: Yep...
PostPosted: Wed Nov 26, 2014 6:29 am
Bronze is used in applications where wear resistance is highly desired being it's a slightly harder material than the tin/copper babbitt. Typically these are seen in industrial applications or constant run high rpm applications, never hear of them being used in auto applications.
PostPosted: Wed Nov 26, 2014 6:35 am
OK that is making some sense. since the /6 was used in some industrial apps. A couple of NOS /6 bronze surfaced rod bearing sets showed up on fleaBay, which is what caused me to ask:
http://www.ebay.com/itm/370627279459?_t ... EBIDX%3AIT
PostPosted: Wed Nov 26, 2014 12:25 pm
The E49 Valiant Charger 265 triple Weber engines had them from the factory in Australia. Pretty sure the Ford inline six had them in early 4 main bearing models .... I saw a main bearing set for on that was bronze,not sure if it was OEM. Nothing special about them,lots of better choices out there these days.
Users browsing this forum: Bing [Bot] and 24 guests
