It is currently Mon Sep 07, 2026 12:27 am
Post new topic  Reply to topic  [ 101 posts ]  Go to page Previous 13 4 5 6 7
PostPosted: Tue Mar 31, 2015 10:49 am
As far as cost, I'm really not going to be much different than a stock go-through of a used head. The valves and components that I'm using are "stock" parts...just not from a Slant.
Port work will be the major difference in price, but is a requirement whether it's naturally aspirated, turboed, or supercharged. More flow is more power.
Brooks
'72 Dart Swinger
'71 Plymouth 'Cuda
Cheap, Fast, Reliable
Pick 2!
PostPosted: Thu May 14, 2015 11:27 am
Grrr. My first real piece of bad news came today...I have to find different retainers. The stock Ford 3.8 retainers pictured earlier are very "tall"...even after grinding the max safe limit on the spring seats, we're still at 120 lbs of seat pressure and limited to .358" valve lift.
My options are thus:
1) Different retainers
2) Thinner spring coils
3) Longer valves
Probably in that order...
Brooks
'72 Dart Swinger
'71 Plymouth 'Cuda
Pick 2!
PostPosted: Thu Jun 04, 2015 6:43 pm
Good news!
Ford Taurus retainers (YFIZ-6514-CA) fixed the deal for $2.42 each. We now have 80 lbs at the seat and room for 0.500" of valve lift.
Given that my flow didn't stall at any point, I'm looking for a cam in the following range: 215 @ .050" and 0.500" of lift. Any suggestions? It'll be a boost motor. What LSA should I be looking for?
Brooks
'72 Dart Swinger
'71 Plymouth 'Cuda
Pick 2!
PostPosted: Thu Jun 04, 2015 7:11 pm
Good news!
You're going to need at least 1.6 rocker arms to get .500" with 215 @ .050
Figure out which lobes will work here:
Cam specs; OCG Mechanical updated 2015-03-21
PostPosted: Thu Jun 04, 2015 8:38 pm
Howards Cam # 751082-12
--> The Diesel Corvette <--
PostPosted: Tue Jun 09, 2015 8:34 pm
Brooks
'72 Dart Swinger
'71 Plymouth 'Cuda
Pick 2!
PostPosted: Wed Jun 10, 2015 8:25 am
Hi Brooks,
I apologize if I am missing this in the rest of the thread, but can you state the exact valve dimensions (head diam, OAL), part numbers or application, and same for springs and retainers. I read through all 7 pages and did not see unambiguous answers. I see the parts list up front, but am not sure which ones you are using in the end.
Thanks very much,
PostPosted: Wed Jun 10, 2015 10:03 am
No problem Lou! I definitely kept my options open because I was afraid of getting stuck in a situation where I couldn't find an off-the-shelf solution.
BTW, the definition of tedious is to look up every 7mm valve on the Sealed Power website so that you can cross-reference search for the corresponding valve spring diameter, all in the name of finding a retainer that may work.
Without further adieu:
Intake: V4488 from Ranger 2.5
Exhaust: V4553 from Ranger 2.5
Springs: VS1648 from Windstar 3.8
Retainers: YFIZ-6514-CA from Taurus 3.0
Keepers: Ranger 2.5
I didn't source guides or stem seals, so I'm waiting on that info.
I believe a better gasket as a template and more experience could net another 10-15 com out of each side. I have another head and Mike J's number...
Brooks
'72 Dart Swinger
'71 Plymouth 'Cuda
Pick 2!
PostPosted: Wed Jun 10, 2015 12:36 pm
Thanks!
PostPosted: Sat Aug 12, 2017 12:38 pm
Sorry to bring up and old thread, but did this ever make it onto a car? how did it run?
 Post subject: Second That
PostPosted: Sat Aug 12, 2017 1:14 pm
Car Model: 1968 Barracuda - Fastback
I second Rick's interest - I've also been waiting for an update. I'd love to do this too...
-Chris
'68 Barracuda - taking advice on increasing street torque, power, & road handling. Click To See It
