It is currently Thu Jul 16, 2026 9:38 pm
 Post subject: Rusty Filler Nozzle
PostPosted: Mon Jun 15, 2015 12:35 pm
As I am finally getting around to replacing my rusty gas tank with a new tank, I noticed that there was rust on my filler nozzle. Most of the rust appears to be on the gas tank side of the nozzle.
To avoid contaminating my new tank, I want to clean the rust off of the end of my nozzle and seal it from rusting again. I was planning to use phosphoric acid or a product like Evapo-Rust to remove the rust. I'm not sure what would be the best way of sealing it. I see from earlier posts that Por-15 and Eastwood have suitable products but I also found on other sites that there were problems with long-term adhesion of those products. It might be that the surfaces weren't properly prepared though.
Has anyone cleaned and sealed their filler nozzles? Any advice for how best to proceed?
1965 Plymouth Barracuda,
225 engine, Quadrajet, HEI, Dutra Duals, 904 Torqueflite, 2.76:1 axle, Addco front bar
Rods & Relics - Fort Erie, ON / Collector Car Tech
Users browsing this forum: Amazon [Bot] and 1 guest
