It is currently Wed May 20, 2026 8:34 am
PostPosted: Fri Oct 23, 2015 6:59 pm
Hey guys so I got a 68 valiant 2 door and I running clifford shortys and my stock 1barrel I just bought a super six with a Weber 38 on it I need to know what the options for kickdown is all the threads I've read are for carters so what do u guys do for a Weber kick down same as the carter or do I have to fab some stuff or find an impossible super six kick down in Cali your help is much appreciated!
Slant six for life!
PostPosted: Fri Oct 23, 2015 8:10 pm
There is no stock kickdown setup that will work with that very-non-stock carburetor. See this thread for kickdown options.
PostPosted: Fri Oct 23, 2015 9:46 pm
Aside from the kick down, you will need to investigate how to properly run your distributor vacuum advance.
PostPosted: Fri Nov 06, 2015 5:42 pm
Check out the thread that Dan suggested.
I have a Weber 38DGS on my slant six, and I'm using a Lokar kickdown cable.
'78 Volare 225
'67 Charger 318
