It is currently Wed Dec 11, 2024 2:48 am
 Post subject: vacuum advance
PostPosted: Sat Mar 13, 2004 4:29 pm
Does a 225 slant six have full or timed vacuum advance? And also what does the timing need to be set at at?
 Post subject: advance
PostPosted: Sat Mar 13, 2004 6:32 pm
Car Model: '63 Dart GT Convertible
The vac. advance works as stated. The 'pull' of yhe carb. vacuum is what moves the spark timing forward. The other advance system is mechanical. Both have limits witch can be adjusted.
PostPosted: Sat Mar 13, 2004 8:32 pm
What year is the Vehicle? Is it stock or have there been any improvements made?
You may want to read thru this article about distributor recurving.
http://www.dutra.org/doug/draft-webpage ... ibutor.htm
