It is currently Sat Jun 13, 2026 5:29 am
PostPosted: Wed Feb 24, 2016 5:08 pm
It seems the Fel Pro compressed head gasket thickness varies on who you talk to (or read on the internet). Is there number that most slanters tend to use? How about a compressed stock steel head gasket. Inquiring minds would like to know.
47 Dodge Custom 4 Door sedan
87 D100 Short Bed slant 6
Retired USAF 1966-1986
 Post subject: It's...
PostPosted: Wed Feb 24, 2016 6:12 pm
Stock shim gasket is around .020- .022
Felpro weighs in from .038 to .043 (if just doing the calc split the difference).
Victor Reinz is similar to Fel-Pro but weighs in on the "heavy side" (but they will take static compression ratios up through 12:1, where as I have had fel-pro fail out on 11:1 SCR engines- but were fine on 10:1 SCR builds)
You will have to do a search if going to the realm of the Aussie Gasket or Copper Gaskets/ O-Rings.
 Post subject: Re: It's...
PostPosted: Thu Feb 25, 2016 1:34 am
Are those numbers compressed or out of the box)
 Post subject: Compressed
PostPosted: Thu Feb 25, 2016 6:13 am
Those are the compressed dimensions.
PostPosted: Thu Feb 25, 2016 6:14 am
Ah OK! Many thanks for your input!
PostPosted: Thu Feb 25, 2016 10:07 am
I have measured maybe 10 Felpro gaskets over the years and they were always around 0.032 - 0.034" compressed (actually as installed in the engine - feeler gauges). The other brands are usually more - in the 0.038-0.46" range. The Aussie Permaseal/Endurotec are 0.044"-0.046" compressed.
