It is currently Mon Sep 07, 2026 4:27 am
PostPosted: Mon Oct 03, 2016 9:30 am
SO the heat riser is busted on our exhaust manifold and the repair kits on ebay are WAAAAAAAAAY expensive......
So looking at new Dorman #674232 units.....$233 on Rock Auto.
WOndering if these new ones are less likely to warp/crack than a used one if I can find one local with no cracks and the riser working?
PostPosted: Mon Oct 03, 2016 10:58 am
At this late date, it's a real fluke if you encounter a "good used" exhaust manifold that's truly good. All of the new aftermarket exhaust manifolds are cast in China. Some of them are better quality than others -- you know how it goes, they might all come from one foundry, but the good ones go to the high bidder, the decent ones go to the next-highest bidder, the passable ones go to the third-highest bidder, and the rejects go to everyone else...then they all get sold on the American market where buyers get no more than what they pay for. The Dorman items tend to be the good ones.
So options are:
• Buy a used one: spend less money, but you have to hope you get one that isn't warped, cracked, or otherwise faulty. Hope it stays that way long enough to make the work worthwhile.
• Buy a cheaper-than-Dorman new one: spend middle money, but you have to contend with poor casting quality and accuracy. Makes it a (literal) pain to install.
• Buy a Dorman new one: spend more money, but "done in one" and you can move on to thinking about things other than exhaust manifolds.
All of the currently-available exhaust manifolds are the '73-up type. They fit and work fine on any year Slant-6 engine, with any intake manifold, but the choke pocket is different to the '60-'65, '66-'69, and '70-'72 choke pockets, which necessitates a choke re-fit. That's not hard; get an electric choke kit to match your carburetor: № 1231 for a Carter BBS or Holley 1920 of any year, № 1234 for a Holley 1945 of any year, and № 1232 for a "Super Six" 2-barrel setup.
It is very much worth your while to get the good gaskets for the manifolds-to-head and intake-to-exhaust junctions.
PostPosted: Mon Oct 03, 2016 11:56 am
There's no single right answer.
Buy a used one: spend less money, but you have to hope you get one that isn't warped, cracked, or otherwise faulty. Hope it stays that way.
Buy a cheaper-than-Dorman new one: spend middle money, but you have to contend with relatively poor casting quality and accuracy. Makes it a pain to install, too.
LOL,..I decided to go with the last .....got a Dorman thru Summit......."its only money"..........sigh.
Actually I didnt see any other options but one, and it was the same cost as the Dorman part number.....so.......
Users browsing this forum: No registered users and 23 guests
