It is currently Sun Jan 12, 2025 1:50 pm
PostPosted: Mon Apr 19, 2004 6:23 am
Can I use a four pin ballast resistor in my two pin car? It was suggested that I could use two of the pins at a time, then if they failed switch the terminals to the other two to get me home. Does this sound right? Need electrical help! Thanks.
PostPosted: Mon Apr 19, 2004 8:09 am
It will work. However, not sure if the voltage difference is something that will give problems down the road.
PostPosted: Mon Apr 19, 2004 12:08 pm
No, this will NOT work properly. The two resistors in the four-pin unit are of very different resistance. Just carry a spare 2-pin unit in the glovebox or, if you want, bolt the spare to the firewall.
Users browsing this forum: Google [Bot], Semrush [Bot] and 3 guests
