It is currently Fri May 08, 2026 8:18 am
 Post subject: oil priming a /6
PostPosted: Fri Jun 08, 2001 1:34 pm
found a 39k mile 72 motor for my wounded demon.
my first peek inside a /6.......
dont appear to be a way to oil prime motor before fire up as pump shaft is engaged to cam.
whats the trick?
maxwedge@webtv.net
 Post subject: Re: oil priming a /6
PostPosted: Fri Jun 08, 2001 8:03 pm
: found a 39k mile 72 motor for my wounded demon.
: my first peek inside a /6.......
: dont appear to be a way to oil prime motor
: before fire up as pump shaft is engaged to
: cam.
: whats the trick?
Just take the cover off the pump and pack it with Vaseline. That's all I ever do.
aschumers@aol.com
PostPosted: Fri Jun 08, 2001 8:43 pm
: Just take the cover off the pump and pack it
: with Vaseline. That's all I ever do.
Yup, that's what I do,I do't even pull-off the cover of the pump, I just pack some Vaaseline into the pick-up port while turning the shaft. Later I crank the installed engine over on the starter untill the oil pressure comes-up. (I leave the spark plugs out) Screw-in the plugs and light it off!
PostPosted: Sat Jun 30, 2018 5:38 am
Car Model: 1987 D150 225
Back feed through oil pressure sending unit with external pump driven from hand drill.
Worked for me.
PostPosted: Sat Jun 30, 2018 8:01 am
I use a pressurized tank I fabbed up, to prelude and fill at the same time.
PostPosted: Sun Jul 01, 2018 11:30 am
Holy thread resurrection Batman! :shock: :mrgreen:
PostPosted: Sun Jul 01, 2018 11:46 am
It took me 30 years to build my car, so I guess 17 years to prime the oil pump is about right! :lol: :lol:
PostPosted: Mon Jul 02, 2018 8:32 pm
Hate to say that I also have some 30 year + projects... still waiting for my attention. :lol:
PostPosted: Tue Jul 03, 2018 11:12 am
With quite a few long term projects still in the offing I must be quite optimistic about my own longevity!
:D
PostPosted: Tue Jul 03, 2018 1:03 pm
As Charlie Brown used to say. "God put me on earth to accomplish certain things, and at the rate I'm going, I'll live forever"!!!!!
PostPosted: Tue Jul 03, 2018 1:54 pm
Car Model: Toad Wagon
Guilty as well. :lol:
And on the priming; in a pinch I've used an air hose to pressurize the crankcase of an installed engine while turning it over on the starter (plugs out of course). Don't recommend it, but it can be done.
Sex, drags, and rock & roll.
Dick, 225% crazy.
Users browsing this forum: Ahrefs [Bot], Bing [Bot], Google [Bot] and 13 guests
