It is currently Wed Oct 07, 2026 6:47 pm
Post new topic  Reply to topic  [ 775 posts ]  Go to page Previous 1 … 27 28 29 30 31 … 52 Next
PostPosted: Thu Aug 15, 2019 3:37 pm
Yeah, kind of a spur of the moment thing. Makes no matter to me, I'm not chasing any records. :mrgreen:
PostPosted: Sun Aug 25, 2019 3:10 pm
Here's how close I came to disaster in Iowa. I saw oil drips on the trailer after I loaded the car yesterday. Mike saw that it was coming from around the oil pump area. I checked the gauge fitting this morning and the pipe finished cracking off.
PostPosted: Sun Aug 25, 2019 4:26 pm
A low oil pressure switch is your friend!! :D :D Glad it wasn't a disaster for you and it is an easy fix.
PostPosted: Sun Aug 25, 2019 4:38 pm
That could have been much worse :shock:
I wonder how much vibration is a factor with a sender and elbow hanging off the end of a pipe like that?
Just trying to see the root cause so I can learn from it.
O==\=/==O
"A mechanic is Somebody."
- Jim Preston
PostPosted: Sun Aug 25, 2019 7:03 pm
Rick, it never lost pressure. If it had broken off it would have been spraying oil in front of the right slick. :oops:
Six, amazingly, on the way to Iowa I was thinking it's about time to replace the fittings and copper line with a braided hose like I have on my 340 car.
PostPosted: Sun Aug 25, 2019 8:06 pm
I'm going to remember that picture the next time I'm tempted to build a plumbing tree :idea:
O==\=/==O
- Jim Preston
PostPosted: Sat Sep 07, 2019 10:36 am
Got my fittings and braided hose. Grand total was $48 and that included 2 hoses since I'm not sure on length.
Will get them in tomorrow. Also need to check the rear end. Something seems not quite right. Maybe I should get my 4.86 together and get it in. :oops:
PostPosted: Thu Dec 12, 2019 4:20 pm
Valiant goes to Teig Chassis Saturday for front end upgrades. We're going to work on it not flopping the wheels all the way in when backing up, and a little better alignment.
Probably pull the Clifford headers out to get them coated too.
PostPosted: Fri Dec 13, 2019 1:58 pm
Cool winter upgrades.
PostPosted: Wed Dec 25, 2019 9:20 am
Spent some time with Patrick yesterday working on the steering. We are putting the rack and tie rods in that came with that POS AJE kit I had for the old Duster. Patrick is also redesigning the mounts. He didn't like the old ones even though the rack had stayed in place for over 20 years. :mrgreen:
PostPosted: Wed Dec 25, 2019 12:46 pm
Does the aje rack fit the oe k frame or does it only fit a tublar frame?
Merry christmas Zilla!
PostPosted: Wed Dec 25, 2019 2:57 pm
Merry Christmas to you too Greg!
The AJE was supposed to be a "bolt in" tube K-frame rack and pinion conversion. Unfortunately it was an ill designed piece of junk.
PostPosted: Wed Dec 25, 2019 4:33 pm
Okay, so I made my own semiublar K frame, maybe I can just buy the rack and adapt it to what I have.
Is the rack / Pinion junk or just the k frame or both?
PostPosted: Wed Dec 25, 2019 6:33 pm
R&P is fine, just the standard Pinto/Mustang II piece.
The issue was the geometry of the setup was horrible.
PostPosted: Wed Dec 25, 2019 6:36 pm
Okay cool.
I never got to look much under that blue 68.. i didnt know it had a rack.
Cheers...
I need to get to a midwest slant meet n greet sometime..
